Stupid axels!!
well i just got home from the track but unfortunatly my car didnt make it back with me... I had some DSS stage 2 axles installed (ment for 400+ hp) and well the passengers side snapped by the hub. and this happend just weeks after i broke a factory axle (it broke inside of the diff) causing major down time waiting for parts. anyone have a clue why a 400+ hp axle would break when I'm only putting down 280 hp?
i have a quaife lsd... when the factory (napa) axle broke it broke inside of the diff and i had to get it repaired.. it seemed to be working fine after it was repaired
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 »</TD></TR><TR><TD CLASS="quote">ive been hearing alot of probs with the dss, people breasking stage 5's alot lately too . </TD></TR></TABLE>
My friend broke stage 1's (inner joint) on the first launch on dry pavement with street tires. He sent them to DSS, they stated they were heat-treated too much....to the point that they were brittle. He got it back and now he is getting real bad vibrations, so he's selling them......
its dropped about 3/4" to 1".... if you want the whole story here it is.... the factory axle has been in for the last 2 years. I have been running the turbo kit and slicks for that time.. the CV went bad so had it replaced. The shop used a Napa axle and snapped the day I got the car back.. car was down about a month because i had to get the diff fixed and the DSS sent me an integra axle at first and it wouldn't stay in the tranny (splines 1/8" too short) so they sent me the right one and 3 days later it broke.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by obsessionx916 »</TD></TR><TR><TD CLASS="quote">yea i no why they broke cuzz drive shaft shop just plain sucks. I had a set of stage 5 axles from them too didnt even get 5 passes on them </TD></TR></TABLE>
DSS stg 5 are the Bomb for low budget (under $10k) racers. My DSS 5 have lasted me almost 30 runs and 600whp passes no brobs yet....now trannies thats another story.
i am about 400 to the wheels on factory prelude axles. i have been using the same set for two years with no problems. i would say it was a defective axle.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kentucky accord »</TD></TR><TR><TD CLASS="quote"> check your motor mounts as well. sloppy mounts=snappy snappy. </TD></TR></TABLE>
I broke 2 oem axles when i went turbo, than when putting in the 3rd i replaced a broken mount and got inserts for my three lower mounts. No more engine shake and no more broken axles.
ROOROWNS
10
May 9, 2005 08:42 PM
