EP3 - Black Housing Headlamps & Side Blinkers?
Old Sep 26, 2003 | 03:54 PM
Kirei's Avatar
Default EP3 - Black Housing Headlamps & Side Blinkers?
Im interested in painting my front lamp housing black and also my side blinkers area. I've seen a lot of people do it but from what I was told, if you spray paint over the chrome, the paint would peel. Has anyone here done it and have experienced that so far? A friend of mine told me that it would help if i sanded it down first before painting. That way the paint would stay. ANy advice? Thanks
Old Sep 26, 2003 | 04:19 PM
EP3CivGrl's Avatar
Default Re: EP3 - Black Housing Headlamps & Side Blinkers? (Kirei)
You really dont want to ruien the healights doing that. If you want the real thing, go to http://www.inlinefour.com there you can find JDM black housing healights. They retail for $400 for a pair. They are pretty sick looking too
Old Sep 26, 2003 | 05:46 PM
siu-p's Avatar
Default Re: EP3 - Black Housing Headlamps & Side Blinkers? (EP3CivGrl)
You need to sanded down the chrome part first. That's how all the RSX fellows do. Use 600 Grit sand paper to sand down the chrome part, then use primer, then 4 ~ 5 coats of high heat black paint.
here's a great walkthur from ClubRsx:
http://forums.clubrsx.com/show...light
Old Sep 26, 2003 | 07:07 PM
Kirei's Avatar
Default Re: EP3 - Black Housing Headlamps & Side Blinkers? (siu-p)
good link. thanks yall!
Old Sep 26, 2003 | 08:38 PM
civicvtec1ps's Avatar
i didnt sand chrome housing at all. dont even need to . just give 5 nice coats of paint and let it dry
Old Sep 26, 2003 | 10:59 PM
sinical-ep3's Avatar
Default Re: EP3 - Black Housing Headlamps & Side Blinkers? (civicvtec1ps)
I didn't sand my housing either, i just masked off the reflective areas and gave it 5 coats of spray paint. I didn't notice until after I was done that I used glossy black paint..but whatever. It looks good. Make sure you seal everything correctly too, because one of my headlights didn't seal all the way, and it fogged up after every car wash before I ended up resealing it.
It probably would've been better if I did sand the housings because if you're up close, you can see where I messed up.
And 400 dollars is costly for some people...(like me)...I prefer the 5-10 bucks I spent...and I get good comments about it all the time, even if they do notice I messed up.
Old Sep 27, 2003 | 08:19 AM
Dunrick's Avatar
Default Re: EP3 - Black Housing Headlamps & Side Blinkers? (sinical-ep3)
never sanded mine...i painted the blinker section black too.....Just do a few coats and a clear coat..
been about 8 months now..
Old Sep 27, 2003 | 09:21 AM
Kirei's Avatar
Default Re: EP3 - Black Housing Headlamps & Side Blinkers? (Dunrick)
I just wanted to make sure because I wouldnt want it to start peeling n everything. Is the gloss just for looks or does it help protect the paint from the sun?
CaliforniaDad
Feb 21, 2010 09:47 PM
Costco
Paint and Body
Mar 31, 2008 07:56 PM
internet ay
Aug 18, 2006 11:24 AM
dan_w_82
Feb 13, 2005 08:44 PM
