clutch is making awful noise!
Old Sep 26, 2003 | 01:33 PM
civickidd99's Avatar
Default clutch is making awful noise!
Alright, it's a '94 vx and the clutch doesn't make any noises when I have the pedal in, but when I start to go it sounds like I'm dragging a large woodland creature. Actually it sounds like a plastic airdam is dragging on the ground, but it's not. The reason i think it's the clutch, is because when I'm stopped and I press the clutch pedal it goes away, but if I let the pedal up in Neutral it makes the noise, just not as bad as when I'm moving. I've been told that it is the throw-out, but I thought the all knowing guru's on here would be able to help. Thanks in advance!
Old Sep 26, 2003 | 02:04 PM
Hatchy-Ownzjo0's Avatar
H-T Poker champion
Default Re: clutch is making awful noise! (civickidd99)
that would be the throw out bearing.. my vx had that horribly before i fixed it with a b18c1!
Old Sep 26, 2003 | 02:13 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: clutch is making awful noise! (Hatchy-Ownzjo0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatchy-Ownzjo0 &raquo;</TD></TR><TR><TD CLASS="quote">that would be the throw out bearing</TD></TR></TABLE>
yay, a correct answer
Old Sep 26, 2003 | 03:00 PM
Sketch_hs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatchy-Ownzjo0 &raquo;</TD></TR><TR><TD CLASS="quote">that would be the throw out bearing.. my vx had that horribly before i fixed it with a b18c1! </TD></TR></TABLE>
yes i think the best solution to the tranny problem is a motor swap, definitely!
-Sketch
Old Sep 26, 2003 | 03:03 PM
H-T Poker champion
Default Re: clutch is making awful noise! (Sketch_hs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sketch_hs &raquo;</TD></TR><TR><TD CLASS="quote">
-Sketch</TD></TR></TABLE>
Don't find a lot of gsr's with bad throwout bearings..
k0rupt_ed
12
Nov 13, 2007 07:05 AM
mm99lude
Aug 19, 2006 07:30 AM
tsdenny
Aug 9, 2006 05:47 AM
EX-T
Oct 9, 2004 04:07 AM
Tad
16
Oct 9, 2003 07:44 PM
