Another ''car wont start'' - no spark HELP PLEASE
Old Sep 26, 2003 | 12:21 PM
Jimmy's Avatar
Global Moderator
Default Another ''car wont start'' - no spark HELP PLEASE
I have a '92 si hatchback (d16z6) and we were on a road trip and my car was on cruise control at 70 mph. All of a sudden i go to accelerate some and i have no acceleration i go down to 4th gear and have no acceleration. The car dies and then i pull over to the side of the road and the car wont start back up..There is like a dark blueish type of spark and all it does is crank...people have told me about the Ignitor and we dont know if its bad or not...all though the little spring on the dist cap was all bent up when we took it off to check...we got to get my car moving within the next 2 days someone please help us....btw: were gettin fuel
my aim-''werdjimmy''
please give ne your thoughts
Old Sep 26, 2003 | 01:16 PM
goodbyegti's Avatar
Ignitor is fairly easy to test, you just need a multimeter and a manual for the specs. It could be the coil as well, you can test the resistance to make sure its in spec. ECU can also cause this if it fails but its unlikely. When my ignitor went it kept cutting out now and again, it didn't just go bang and stop working. I don't know what the spring does, does it earth a lining in the wire or something? anyway i'd fix it...
Old Sep 26, 2003 | 01:20 PM
Kamin's Avatar
Default Re: Another ''car wont start'' - no spark HELP PLEASE (USDMDC2)
odds are its eithre the cap, rotor or igniter.
if you can get another d series distributor you can just swap them and check.
cap and rotor are cheap to replace.
Old Sep 26, 2003 | 01:32 PM
goodbyegti's Avatar
yeah good point kamin, check the obvious stuff first...
Old Sep 26, 2003 | 01:35 PM
Jimmy's Avatar
Global Moderator
Default Re: (goodbyegti)
but what if it aint the ovious stuff? and yeah btw when i turn my car off now it kind of shakes a little...i hope its nothing serious...please help guys...where were located right now they dont have an ignitor in stock and i gotta be homme sunday
TTT
Old Sep 26, 2003 | 01:42 PM
Kamin's Avatar
Default Re: (USDMDC2)
lets look at the more ovbious now
spark plug wires.
make sure all are properly seated on the spark plugs AND distributor. that last statment makes it sound like you are running on 3 cylinders
Old Sep 26, 2003 | 01:56 PM
Jimmy's Avatar
Global Moderator
Default Re: (Kamin)
ttt..anyone else
Old Sep 27, 2003 | 08:12 PM
Jimmy's Avatar
Global Moderator
THANK YOU EVERYONE....
friday night we went to my car ( after sitting on the road of an alabama hwy)
everything was intact....we put a new coil in it ...NO start...we put a new ignitor in it...cranked her right up....thanks everyone so much...**** like this makes me wish i could give honda-tech an award...bc if it wasnt for you guys i would of had to have my **** towed all the way back to knoxville. THANKS GUYS
Old Sep 28, 2003 | 02:10 PM
goodbyegti's Avatar
good to hear its all sorted... my ICM first went bad when i was overtaking someone..the whole thing just cut out and I had to pull back...! Just as a tip its always worth sticking the ICM screws with locktite just incase they vibrate free and you should always use some silicone grease to help heat dissapation...it's not essential but its always a good idea...
CuteAccord
37
Jan 3, 2009 10:41 AM
dohctor_B
Feb 3, 2006 04:26 AM
krazn
Dec 5, 2005 10:02 AM
Ace of Spades
Feb 21, 2005 05:14 PM
Jimmy
Sep 27, 2003 08:10 PM
