How to remove rear seats from 4dr g3 teg?
Old Aug 25, 2001 | 11:48 AM
leechungsr's Avatar
Default How to remove rear seats from 4dr g3 teg?
Where/what do I remove to take out my rear seats? Thanks!
Old Aug 25, 2001 | 01:52 PM
SlipAngleX's Avatar
Default Re: How to remove rear seats from 4dr g3 teg? (LeeChun GSR)
You'll first have to take off the rear seat where your back rests. Good way to get to it is taking off the side bolster where the seatbelt rests. (the long rectangle piece that is parallel to the seatbelt) There is one screw 10mm? That is on the bottom of the bolster, so you'll have to dig your hand in-between the bolster and the bottom of the seat. When you take that off, you'll be able to get to the 2 other same sized screws that hold the main back rest of the seat. Do this for the other side, and presto, the backrest part of your seat will come out along with the carpeting that covers the spare tire. The bottom is really simple. There is one bolt in the middle area (you'll see it when you take the backrest portion out) Then you'll have to pry it off. Lift the back end upward tward the front seats.
I hope you understand all that jumble, I just typed. if any questions, feel free to ask!
Old Aug 25, 2001 | 06:09 PM
leechungsr's Avatar
thanks! Weight Reduction Stage 1 almost complete.
despite having a friend at Circuit City and a friend at Best Buy (both Fatty audio discounts.), I decided to lighten up a little
Old Aug 25, 2001 | 06:11 PM
keys's Avatar
Default Re: How to remove rear seats from 4dr g3 teg? (4DoorTeg)
yeah he's right, but lemme try and explain too....
-fold down your rear back rests and pull off the 1-piece black trunk cloth
-there you'll see 4 bolts near the bottom corners (2 each side) take those out and the back rest comes off
-to remove the rear seat there's 1 bolt near where the middle seat belt locks into, take that out and you can pull the seat off, pull it from the back because there's hooks in the front
-once that's out, the side bolsters remain and each one has 1 bolt on the bottom where the seat would've covered them, take those out and then pull straight up on the bolsters to remove them.... you could've also done this before the bottom seat, but i think it was hard for me to find the bolt underneath it
hope this helps
Old Aug 27, 2001 | 06:12 AM
owen_the_soyboy's Avatar
Default Re: How to remove rear seats from 4dr g3 teg? (keys)
yeah what KEYS said.
Milano_EH3
Jan 17, 2005 08:31 AM
optikal_blitz
Jan 29, 2003 02:09 PM
Nocturnal
Jan 7, 2003 11:42 AM
bananacruzier
Apr 17, 2002 11:22 AM
daniel89civ
Mar 13, 2002 05:11 PM
