Clutch Master Cylinder help needed
Old Sep 26, 2003 | 10:32 AM
JoJa15's Avatar
Default Clutch Master Cylinder help needed
Will a 1997 Integra Type-R clutch master cylinder work on a 1993 Civic Si HB? I think my clutch master cylinder is going out on my car. I already have the engine, and transmission from a 1997 Type-R in my Civic Si HB. I called the local Honda parts store and they quoted me $139.54 for a new Civic clutch master cylinder. I called the local Acura parts dealer and they quoted me $113.81 for a new Type-R clutch master cylinder. Obviously I want to go for the less expensive one but I wanted to make sure that it would bolt up to the Civic firewall and work with the Civic clutch pedal.
I was also wondering if anyone could recommend some good online sites to buy new Honda/Acura parts at a good price?
Best Regards,
John
Old Sep 26, 2003 | 10:39 AM
EL Vap133's Avatar
Default Re: Clutch Master Cylinder help needed (JoJa15)
Does your Si currently have ABS?
Old Sep 26, 2003 | 10:52 AM
JoJa15's Avatar
My Civic Si does not have ABS.
Would not having ABS prevent me from using the Type-R clutch master cylinder? It is my clutch system not my brake system that is messed up. Both the Civic and Type-R have hydraulic clutches that use hydraulic pressure to release the clutch. I think my Civic clutch master cylinder is leaking. The leak is causing low pressure in the hydraulic line which prevents me from disengaging the clutch.
- John
Old Sep 26, 2003 | 11:20 AM
elwood's Avatar
Default Re: (JoJa15)
I don't think that he read your post. They are mostly all the same.
I have many for sale.
Old Sep 26, 2003 | 11:37 AM
EL Vap133's Avatar
When I got a Teg MC and brake booster for my CRX, I had to use one from a Teg with no ABS to make it work in my car. Therefore, if your car has ABS then you need a MC and BB from a car that has ABS, if your car does not have ABS then you need one from a non-ABS car.
MasterLink4253
Jun 9, 2014 07:22 AM
noidg101
Honda Civic (2001 - 2005)
Jun 1, 2008 06:24 AM
lopey
May 13, 2003 10:57 PM
