Tire Pressure Guidelines.
Old Aug 25, 2001 | 10:13 AM
Quick Silver's Avatar
New User
Default Tire Pressure Guidelines.
Ok, guys I'm new here;
And I need some help,
What tire pressure should I be running on a street set-up for:
215/40/17 tires on my 3680Lbs. Heavy Ls?
I am looking for a good compromise between grip and tire/gas wear/economy
Any imput is apreciated.
Thanks
Old Aug 25, 2001 | 10:48 AM
New User
Default Re: Tire Pressure Guidelines. (Quick Silver)
I Looked at the sticker on my door with the weight specs and thats what it says 3680Lbs. ??
Old Aug 25, 2001 | 11:32 AM
New User
Default Re: Tire Pressure Guidelines. (Teken)
Thanks A lot for the Help Teken!
I'm gona try to go 35psi, and play with it up or down to see where it takes me..
Old Aug 25, 2001 | 11:52 AM
leechungsr's Avatar
It must be 2680 pal. DB8GSR's 4dr Greddy Turbo weighed in at 2700 with full leather everything..
Old Aug 25, 2001 | 01:35 PM
buji's Avatar
New User
Default Re: Tire Pressure Guidelines. (LeeChun GSR)
I am going to guess that the door sticker is the maximum loaded weight.
4-doors are about 100 lbs heavier than 3-doors.
-buji
Old Aug 25, 2001 | 06:35 PM
VTECAcuraGSR's Avatar
Default Re: Tire Pressure Guidelines. (buji)
Buji is right, that is the maximum the car should wieght. So you should only load the car with 600 lbs worth of stuff! It does not weight that though. Damn, Thats as heavy as a lincoln or something!
Old Aug 25, 2001 | 06:54 PM
New User
Default Re: Tire Pressure Guidelines. (VTECAcuraGSR)
You guys must be right, I thought that was a bit heavy for my car...
I'll check into that,
and as for the tires I went Front:35Psi, Rear 32Psi
Thanks for the replies, and the warm welcome guys!
Old Aug 25, 2001 | 08:04 PM
kikkoboyie's Avatar
New User
i got 35 in the front and 32 in the back 2.... thats the stock recommendation...
i noticed if u go lower the ride is smoother though over bumps... but tires will screech more on hard turns
CD5B2
Apr 28, 2012 08:08 AM
benji7288
Nov 21, 2007 01:21 PM
.water
Apr 1, 2006 07:05 PM
MNCRXSi
Jun 20, 2005 10:02 AM
94ls
Jun 19, 2003 02:53 PM
