88 DX HB doors on a 90 SI HB
Old Sep 26, 2003 | 08:10 AM
tpr's Avatar
tpr
Default 88 DX HB doors on a 90 SI HB
I want the seatbelt setup from the 88. the feel of the 90 SI with the mechanism in the door is different. I also like the way the 88 hold you in better. Is it possible??
Old Sep 26, 2003 | 08:14 AM
YumVTEC's Avatar
Default Re: 88 DX HB doors on a 90 SI HB (tpr)
it would be a huge PITA, not worth it IMO. You'd need the rear interior 1/4 panels from the 88, along with the seatbelt assemblies, and door panels, and you'd probably have to do some custom work to make everything fit.
Old Sep 26, 2003 | 10:29 AM
Its entirely possible. all of the 90-91 b pillars have holes pre drilled to mount the 88-89 seatbelts. You will have to weld in a few minor things. take a look at your 90-91 b pillar vs your 88-89. you'll instantly see what you need and its not much.
Old Sep 26, 2003 | 10:36 AM
tpr's Avatar
tpr
Default Re: 88 DX HB doors on a 90 SI HB (Manhattan Auto)
Thanks! I have a donor car so that will make this a simple process. So the issues are small and will require only light welding. I assume a set of nuts in the B pillar. the 88 doors are alot lighter and i just like to be able to cinch down the lap belt. You can't do that with the 90-91 setup.
Old Sep 26, 2003 | 01:09 PM
b16_madman's Avatar
I had a 90 si shell that had a 88-89 door on one side. The shell was a pos, later trashed.
88-89 doors do fit, but the only snag are the black support things in the 90-91 door jams towards the top of the jams.
They will come out, but only with a bunch of beating or some nice power tool.
Ldo
21
Apr 19, 2014 07:39 PM
wasabivtec
15
Jan 5, 2011 12:49 PM
VtecKiDD
May 3, 2004 09:50 AM
dropd4door
28
Dec 18, 2002 08:21 PM
Steve91
11
May 21, 2002 05:40 PM
