How I Plan To Keep My Hands Clean With My H1 Car
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sackdz »</TD></TR><TR><TD CLASS="quote">You're going to use stock A arms????</TD></TR></TABLE>
thinking the same thing
they don't look like lower civic arms to me...
[edit] lower
Modified by Willard at 8:05 AM 9/26/2003
[edit] lower
Excellent idea - you will save hours over the life of the car, not having to deal with yuck. I would not do the calipers, however, thinking that the coating would act as a thermal barrier (albeit a small one) on a part that you want to shed as much heat as possible. I have no empirical evidence to back this up but there you go...
Kirk
Kirk
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Willard »</TD></TR><TR><TD CLASS="quote">
They are GSR LCAs and the knuckles are off Gordon's RS.
I got the upper arms coated prior to knowingthat I couldn't get ball joints by themselves. These were to just get the car on the road since it will be street legal (at least it's got an inspection until 6/04
I'll most likely fabricate custom upper control arms with replaceable ball joints to incorporate camber and caster adjustments.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SMSP »</TD></TR><TR><TD CLASS="quote">I got the upper arms coated prior to knowingthat I couldn't get ball joints by themselves.</TD></TR></TABLE>what about adjustable ball joints?
http://www.autocarparts.com/part/932/87
caster adjustments?
is the new rule book out yet?
caster adjustments?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Willard »</TD></TR><TR><TD CLASS="quote">what about adjustable ball joints?
http://www.autocarparts.com/part/932/87</TD></TR></TABLE>
Hadn't seen those but I'm looking for something that has a more positive way of keeping everything in place under load.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Knestis »</TD></TR><TR><TD CLASS="quote">I have no empirical evidence to back this up but there you go...
Kirk
Makes sense.
Clean partz.
Kirk
Makes sense.
Clean partz.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda318dx »</TD></TR><TR><TD CLASS="quote">Dave, it looks great till you blow that axle
I don't plan to purchase axles where you got yours.
</TD></TR></TABLE>I don't plan to purchase axles where you got yours.
I don't plan to purchase axles where you got yours.</TD></TR></TABLE>
dont plan on running 5 degrees caster either
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SMSP »</TD></TR><TR><TD CLASS="quote">I'll most likely fabricate custom upper control arms with replaceable ball joints to incorporate camber and caster adjustments.</TD></TR></TABLE>
I want a set too
I want a set too
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by baonest »</TD></TR><TR><TD CLASS="quote">too much weight.
sand them back down</TD></TR></TABLE>
How much extra does it really weight?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VWkila »</TD></TR><TR><TD CLASS="quote">
How much extra does it really weight?</TD></TR></TABLE>
as much as the sarcasm that was used.
ounces. . .I'm guessing he was being sarcastic. . .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Knestis »</TD></TR><TR><TD CLASS="quote">Excellent idea - you will save hours over the life of the car, not having to deal with yuck.</TD></TR></TABLE>
Although they do look nice, how does it keep your hands clean? Or was it a joke that went way over my head?
although a good idea to keep things cleaner
it will be harder to inspect for hairline cracks.....
all those parts can be wear items....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR »</TD></TR><TR><TD CLASS="quote">although a good idea to keep things cleaner
all those parts can be wear items....</TD></TR></TABLE>
LCAs and steering knuckles...wear items?
TeamSlowdotOrg
24
Mar 21, 2004 02:53 PM
