Thoughts on Engergy Suspension motor mounts?
Old Sep 25, 2003 | 06:06 PM
SsTiNgEr77's Avatar
Default Thoughts on Engergy Suspension motor mounts?
for a cheap little mod of about 40 bucks? what is the purpose of it? does it reduce vibrations?... description says:
Controls torque, diminishes wheel hop and improves manual transmission shifting.
• A must to use with modified motors and if you're heavy footed!
• Protects your existing O.E.M. rubber mounts from tearing.
• Even works with torn O.E.M. mounts.
• Can be removed later for stock running, if so desired.
• Installs in just 5 to 10 minutes on Accords and Civics!
• Durable HYPER-FLEX™ performance polyurethane construction
so... attack it?
Old Sep 25, 2003 | 06:55 PM
Jeff33S's Avatar
NO it does not decrease vibrations... actually they will increase vibrations as the motor is now more solid with the car...
Benefits yes helps to reduce wheel hop some and you can feel when shifting everything is more solid..
They dont install in 10 minutes as the rear mount is a pita to work on, but not that bad...
I have them and not bad for the 40 bucks if you can deal with the extra vibrations in your car
-Jeff-
Old Sep 25, 2003 | 08:14 PM
satan_srv's Avatar
Default Re: (Jeff33S)
I just put in the front. That's really the only place you need it.
Old Sep 25, 2003 | 08:20 PM
del_parker's Avatar
Default Re: Thoughts on Engergy Suspension motor mounts? (SsTiNgEr77)
the rear is a total pain in the *** and i wouldn't install it unless you're doing something else back there as well.
i waited until i took my transmission out again...
also, to fix a torn motor mount, try using some plastic welding epoxy or something similar. fixes the tear pretty good and stiffens it up a little bit too.
Old Sep 26, 2003 | 12:55 AM
preluda92's Avatar
Default Re: Thoughts on Engergy Suspension motor mounts? (del_parker)
Anyone out there make a more solid full replacement mount? Inserts are good but, I'd like something a little more solid.
Old Sep 26, 2003 | 04:53 AM
iakona's Avatar
seriously, get the inserts in and you'll think twice about a solid mount. you won't need it.
and if anyone's interested, i have a set for a 4th gen.
Old Sep 26, 2003 | 05:26 AM
Finest's Avatar
Default Re: (iakona)
My dash shakes on moderate to hard launches. heh heh
The rear mount was easy...since I already had the motor out.
white_db8
May 26, 2007 09:34 AM
teddy_dc2
May 2, 2006 10:32 PM
CpRiCe87
13
Mar 27, 2006 07:37 PM
Novtecdohc
May 15, 2005 05:24 PM
EF_yo_89
23
Jun 2, 2004 03:53 PM
