JDM GSR header collector size??
Old Sep 25, 2003 | 04:18 PM
AtomiK_EK's Avatar
Default JDM GSR header collector size??
I've done some searching and someone posted that the collector size is 2.5"
Is this correct? Can I swap this header with a JDM ITR header without and problems? Is it even worth it?
Thanks for any replies!
Old Sep 25, 2003 | 06:31 PM
Dave-ROR's Avatar
Default Re: JDM GSR header collector size?? (AtomiK_EK)
2.5" 4-2-1 I thought, maybe 2.25" though, not sure honestly. not as tiny as the USDM one
Old Sep 25, 2003 | 08:02 PM
mugenracer's Avatar
Its 2.25" OD but ID is only 1.75", its double walled. I have a JDM GSR and run a DC JDM 4-1 into the stock cat, it seals pretty good even though the DC donut gasket is slightly bigger than the cat inlet flange.
See picture in this post...... https://honda-tech.com/zerothread?id=470521
Old Sep 25, 2003 | 08:16 PM
AtomiK_EK's Avatar
Default Re: JDM GSR header collector size?? (mugenracer)
Thanks!
So the JDM ITR header should fit right?
Old Sep 26, 2003 | 03:31 PM
mugenracer's Avatar
That depends on what your fitting it to? If you fitting a DC JDM to a stock GSR cat, then no it wont fit, if its to a stock JDM cat then yes it will fit!
Old Sep 26, 2003 | 06:31 PM
AtomiK_EK's Avatar
Default Re: (mugenracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenracer &raquo;</TD></TR><TR><TD CLASS="quote">That depends on what your fitting it to? If you fitting a DC JDM to a stock GSR cat, then no it wont fit, if its to a stock JDM cat then yes it will fit!</TD></TR></TABLE>
Thats what I was wondering I have a JDM GSR header with stock JDM cat. Thanks!
Mike Ockhurts
10
Oct 21, 2004 03:58 AM
aclw2
Apr 15, 2004 05:17 PM
Kolijian
Mar 8, 2002 01:46 PM
hybrider
Feb 23, 2002 01:12 PM
