Cranking slow
Old Aug 24, 2001 | 08:03 PM
leechungsr's Avatar
Default Cranking slow
My car was in the body shop for about 3 weeks. I noticed when they were doing a final wash, they let my car idle.
I drove home, and everything was normal. It is a 20minute drive. When I went to start it up again, the motor would BARELY crank, and wouldn't even start. We had to start it on a rolling push..I drove around for a bit. Then, I started again, and it cranked slowy, but started. It cranks slowly and starts up (this happening about 4 times today)
When the car sits and is moved occasionally for 3 weeks, does it drain the battery? I believe the charging system is okay, since I'm not getting a battery light on the dash.
Old Aug 24, 2001 | 08:25 PM
yaksplat's Avatar
Default Re: Cranking slow (LeeChun GSR)
i had something like this happen
there was no visible corrosion on the terminal, but inbetween the lug and the terminal there was
it was a bitch until i figured it out and cleaned it up
little Mary
Feb 28, 2018 05:47 AM
91b16acrx
Nov 16, 2008 06:41 AM
SlammedDC2
16
Dec 24, 2006 06:55 PM
snzh22
Nov 13, 2006 01:46 PM
wompwomp61
17
Nov 4, 2004 02:17 PM
