OVER HEATING Check list...questions? here are the answers
Old Sep 25, 2003 | 09:57 AM
chad's Avatar
Moderator
Default OVER HEATING Check list...questions? here are the answers
Car overheats.....
1. Does your fan turn on?
if not then make a hot wire to fan to see if it works.
if not then you need a new fan
if fan comes on when hot wired
check fuses....
if fuses are good
change thermoswitch
If fan still doesn't come on, wire up with swith and manuelly turn it on.
2. Fan comes on but still heats up
Change thermostat
3. Fan comes on, you changed thermostat and still heats up
FLUSH YOUR SYSTEM.....possible your water pump is not working (yes it is possible for it to stop working and your timing belt will still be fine)
anything else??
please use this for over heating problems!!! this does not include holes in lines leaky systems....
late
chad
Old Sep 25, 2003 | 10:00 AM
Johnny Tran's Avatar
Default Re: OVER HEATING Check list...questions? here are the answers (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">anything else??</TD></TR></TABLE>
4. remove clown shoes, and flee the R and D premises. If problem still occurs, set car ablaze and write it off as a total loss.
Old Sep 25, 2003 | 10:07 AM
degooser's Avatar
let car run with rad cap off till all air bubbles are gone...
keep filling the radiator...
Old Sep 25, 2003 | 10:44 AM
ill phil's Avatar
Default Re: OVER HEATING Check list...questions? here are the answers (degooser)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by degooser &raquo;</TD></TR><TR><TD CLASS="quote">let car run with rad cap off till all air bubbles are gone...
keep filling the radiator...</TD></TR></TABLE>
Can also be the cause of surging idle after adding coolant
A good helpful tech post Chad - sadly I know most the people in the this forum are too damn lazy to search or even look for this down the line
Old Sep 25, 2003 | 11:09 AM
Dancing is Forbidden's Avatar
Default Re: OVER HEATING Check list...questions? here are the answers (ill phil)
a tech post from CHAD? NOOOOOOO!!! Ryan must be using Chad's screenname again
Old Sep 25, 2003 | 12:52 PM
chad's Avatar
Moderator
Default Re: OVER HEATING Check list...questions? here are the answers (EF9_SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF9_SiR &raquo;</TD></TR><TR><TD CLASS="quote">a tech post from CHAD? NOOOOOOO!!! Ryan must be using Chad's screenname again </TD></TR></TABLE>
ryan with a tech post....now that makes me laugh....and is pure clown shoes!
Eglifestyle
10
Mar 23, 2008 12:08 PM
jeezyskillz
Nov 3, 2006 06:20 AM
bon3
Jun 21, 2005 06:00 PM
wsiracerz
Jun 7, 2004 12:08 AM
boostedeghatch
10
May 12, 2004 06:39 PM
