swapping 98 civic dx d16y8 into my 91 civic dx hatch, what clutch, flywheel, dizzy, etc?
i know most of this is a bolt in operation, and i'm already wired and set for the mpfi, i just need to know which parts to use from which engine, right now, in the car is a crx hf motor, with Si tranny, Si ecu, 93 dx intake mani, Si distributor
and the new motor is a stock 98 civic dx, and i have everything with it, including axles
could someone please let me know what setup to put in? i have been told the 98 motor, the Si tranny, Si distributor, the 93 dx intake mani, keep running the Si ecu, do i need to switch the flywheel? or just the clutch? which axles should i use?
i appreciate any help
thanks, i wasn't sure if the clutch/pp/flywheel would interchange, since the 98 motor uses a hydro tranny, this makes me happy though, so all i need to do is swap the trannys? no need to do anything to the clutch?
just want to make sure
mr_hahn73
Nov 11, 2005 05:58 PM
CRXalwysk8
13
May 3, 2005 07:18 AM
sohcvtec66
Nov 18, 2003 09:49 AM
