LS/Vtec dyno numbers, 1320 times.
I was just looking for some dyno numbers of built LS/Vtec motors.
I couldn't find any so please post up your setups, and numbers.
Another thing that I'm looking for time slips from all you drag racers out there.
I'm wondering on what kind of times would I be able to pull with +/- 200 whp LS/Vtec powered EM1.
I know questions like this are pretty much lame and not appreaciated but I would like drag racing LS/vtec owners to post up some times for me.
Thanks.
Thanks.
All Motor
Ls/Vtec
Si(R) P30 pistons
Ls rods/Arp rpd bolts
Stock Type R head and Intake Manifold (unported)
65mm Throttle Bodie
Crower cams and Valvetrain
P08 ecu chiped
Field Vtec controler
c12 race gas
jdm dc 4-1 header
estimated weight is 1800lb
0.577 Reaction
1.671 60 ft
blank 330 ft
7.702 1/8 ET
88.96 1/8 MPH
12.104 1/4 ET
110.61 1/4 MPH
Modified by shant at 5:34 PM 9/26/2003
Ls/Vtec
Si(R) P30 pistons
65mm Throttle Bodie
P08 ecu chiped
c12 race gas
jdm dc 4-1 header
0.577 Reaction
1.671 60 ft
blank 330 ft
7.702 1/8 ET
88.96 1/8 MPH
12.104 1/4 ET
110.61 1/4 MPH
slicks of course. but was huge 15" slicks to fit over my 5-lug brakes.
took out bumper support, rear seats, useless panels, a/c, p/s...etc.
still have oem glass all around and original door & panel. STREET CAR.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s2geezy »</TD></TR><TR><TD CLASS="quote">2001 PY ITR
1.8l ls/vtec
189whp/139wtq
12.9@105mph
2370lbs with driver.
1.8l ls/vtec
208whp/139wtq
hopefully low 12s @ xxx mph
even lighter chassis.
What parts are you running under those setups? Or is that top secret...
1.8l ls/vtec
189whp/139wtq
12.9@105mph
1.8l ls/vtec
208whp/139wtq
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VolpeOwnsU »</TD></TR><TR><TD CLASS="quote">
its no secret.
see my car info: https://honda-tech.com/zerothread?id=569765
basically just a 1.8l stock sleeve, with high cr pistons, and skunk2 cams.
</TD></TR></TABLE>its no secret.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tommySI »</TD></TR><TR><TD CLASS="quote">I was just looking for some dyno numbers of built LS/Vtec motors.
here is a comparison of a 1.8 liter ls/vtec motor comparing impact of a skunk2 intake manifold vs TWM ITBs:
mods were Endyn pistons 81.5mm bore, 12.8:1 dome, stock GSR head, Hytech header, combination Toda cams ... built and tuned by me using speedpro/FAST engine management.
HTH,
Greg
HTH,
Greg
thats a monster, especially for a stock non ported head
when u say combination toda cams, which did you use?
Greg combines different Intake\Exhaust cam to reduce the overlap on the todas.
Like a C Intake with a A Exhaust...**** like that.
Suprdave
Suprdave
Bumper supports are only for 5mph collisions anyways...Hit something going 40-50 and your screwed either way.
Suprdave
Suprdave
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JD Milan »</TD></TR><TR><TD CLASS="quote">nice times,,,honestly no bumper supports hardly a street car, hope you don't hit anything mang..</TD></TR></TABLE>
i dont plan to crash my car.
i drive it like that on the street. all my friends do.
a light hit isn't going to hurt, on the other hand bumper supports aren't goin to help if its a major accident.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CHEETAH »</TD></TR><TR><TD CLASS="quote">
HTH,
Greg</TD></TR></TABLE>
whoa that is some serious power with a 1.8L ls/vtec with stock gsr head!!! im curious what combo to the toda cams did u use??
HTH,
