h22a cam gear setting
Old Sep 24, 2003 | 08:02 PM
HYBRIDJDM WAGON's Avatar
Default h22a cam gear setting
ok everyone with skunk2 cam gears or other cam gears. what people here has dyno'ed their h22a with adjustable cam gears at wht degree settng for best max power, mor hp, or feels alot stronger. i am currently at 9.01 compression for 3 years, hard to come up with money to finish my turbo set up but anyway im trying to get a 14'8 in my 9.01 compression wagon, almost there but also my wagon is auto and the 5 speed swap is on its way soon as i can fnd a stage 4-5 clutch.
the point is whre do u people keep the settign nest at on the intake and exhuasr side of the cam gears?
Old Sep 24, 2003 | 08:08 PM
Cottonwoodz's Avatar
Default Re: h22a cam gear setting (HYBRIDJDM WAGON)
Pay for half of my Dyno Time and I will tell you..
Old Sep 24, 2003 | 08:18 PM
sharkcohen's Avatar
Dude, you don't just use someone elses settings. It most likely will make your engine run worse. Every setup is going to be different. On top of that, you are just asking it as a general question and you are running lower compression and boost. Cam settings on an NA setup are not going to help you. You MUST adjust the gears while on a dyno with a wideband, and they should be the LAST thing you tune. If I were you I would be much more concerned about getting boost tuned properly first.
Old Sep 24, 2003 | 08:57 PM
KTeller8's Avatar
dont listen to them
move your intake cam 4 degree tot the left and exhaust cam 2 degreess to the righ
then you should hit bout 200whp but by that alone
edit, scarcasm
Modified by KTeller8 at 12:54 AM 9/25/2003
Old Sep 24, 2003 | 08:58 PM
KTeller8's Avatar
#1 stunna
Old Sep 24, 2003 | 09:40 PM
Default Re: (KTeller8)
ADVANCE THE INATEK SIDE 4 DEFREE AND RETARD THE EXHUAST TO 2 DEGREE?
Old Sep 25, 2003 | 12:16 AM
@ries's Avatar
go dyno yo shezee mang!!!
Old Sep 25, 2003 | 01:12 AM
satan_srv's Avatar
Default Re: (HYBRIDJDM WAGON)
he was kidding.
Seriously you have to go to a dyno. Changing cam gear settings changes fuel needs so you can't see if it gains until you adjust the fuel as well. You need dyno + wideband yo!
Old Sep 25, 2003 | 01:07 PM
KTeller8's Avatar
Default Re: (satan_srv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv &raquo;</TD></TR><TR><TD CLASS="quote">he was kidding.
Seriously you have to go to a dyno. Changing cam gear settings changes fuel needs so you can't see if it gains until you adjust the fuel as well. You need dyno + wideband yo!</TD></TR></TABLE>
yeah i was kidding.. i edit the post with the word Scarasim just so you know
only on a dyno would you know... mine are set at 0 straight up, till i can get to a good dyno
FloGgY
Mar 19, 2007 07:41 PM
myh22a
Aug 12, 2005 05:10 AM
dvp95
Apr 15, 2004 02:07 PM
Showoff
Oct 30, 2003 04:20 PM
vwong
Jan 24, 2003 10:45 AM
