Quick question before I do my swap......(pics)
Old Sep 24, 2003 | 06:03 PM
1.8t's Avatar
Default Quick question before I do my swap......(pics)
I posted in they hybrid forum, but no one ever says anything in there unless you post pics of a 500whp built something or other swapped into a hatch...so, I will ask here. Lock it if you want, maybe you can go respond on the hybrid forum.
I was tracing wires today just to make sure everything was lining up, when I noticed the differences between the stock engine and the LS engines harness going to the battery. Here is a pic of the stock
http://www.auburn.edu/~mcgowmd/stock.jpg
Notice one wire to the battery and one to the fuse box. Now, on the LS harness, it has one to the battery, one to the fuse box, and then another thick white wire coming off the connection for the battery. Where does this one go? Is it just another ground. Everything matches up perfectly other than this.
Here is the pic of the LS harness
http://www.auburn.edu/~mcgowmd/ls.jpg
Old Sep 24, 2003 | 06:11 PM
Pho Real's Avatar
Default Re: Quick question before I do my swap......(pics) (1.8t)
Can someone post that cute bunny picture?
Old Sep 24, 2003 | 06:13 PM
Jmunk's Avatar
Goes to the starter i think. I believe that is the wire that gives it power.
Old Sep 24, 2003 | 07:04 PM
ransack's Avatar
Default Re: (Jmunk)
ummm I ran outside to check my car cuz I got an LS and then im like, whoa, I used a civic harness.
like you should be
whatever that is, you dont need it. you should only be concerned with the civic harness
Old Sep 24, 2003 | 07:08 PM
1.8t's Avatar
Default Re: (ransack)
Thanks.
Old Sep 24, 2003 | 07:14 PM
SleepyEG's Avatar
Default Re: (1.8t)
It's not for the starter, the thick white is for the ABS...so don't worry about it, unless you have ABS of course.
~james
Atomic1
Jun 18, 2014 02:45 PM
DailyDriven259
May 11, 2012 11:31 AM
92HB_HB
Aug 23, 2006 06:57 PM
BLUE EH3
Aug 10, 2004 04:18 PM
1.8t
Sep 25, 2003 08:41 AM
