Header bolt hatred....
Old Sep 24, 2003 | 05:22 PM
cruzersi99's Avatar
Default Header bolt hatred....
Top left header bolt refuses to move. I know that they were properly torqued because I watched when it was done. Nothing special done to this bolt, and yet, everything I do results in the head of the bolt deforming. Any suggestions??
Old Sep 24, 2003 | 05:28 PM
DarthLuder's Avatar
New User
Default Re: Header bolt hatred.... (cruzersi00)
Use a torque bar for added leverage.
Old Sep 24, 2003 | 05:31 PM
cruzersi99's Avatar
Default Re: Header bolt hatred.... (ITR GURU)
i'm not sure if it's leverage more than the bolt just won't move. instead the head of the bolt is giving and stripping.
Hatred....
Old Sep 24, 2003 | 05:39 PM
hungsteR's Avatar
Use a breaker bar or take it to someone else to remove before you strip it any worse.
Old Sep 24, 2003 | 05:59 PM
Philly_NBP_R's Avatar
Default Re: Header bolt hatred.... (hungsteR)
get a good penetrating oil on there (like AeroCroil if you can find it - or liquid wrench if you can't). Let that sit over night. Try a big breaker bar, and if the bolt strips - hammer on a slightly smaller socket. Good luck.
Old Sep 24, 2003 | 06:43 PM
jdmspoonitr's Avatar
Default Re: Header bolt hatred.... (Philly_NBP_R)
If you are stripping the bolt.....you might not have a perfect fitting socket. I remember I had some cheap tools that didn't fit exactly. The extra space put all of the torque on the corners of the bolt instead of on the flat part resulting in a stripped bolt.
Get better tools.
Old Sep 24, 2003 | 07:58 PM
sackdz's Avatar
Default Re: Header bolt hatred.... (jdmspoonitr)
Use a 6pt socket, not 12.
Old Sep 24, 2003 | 08:41 PM
98ITR#0020's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hungsteR &raquo;</TD></TR><TR><TD CLASS="quote">Use a breaker bar or take it to someone else to remove before you strip it any worse.</TD></TR></TABLE> .. You could try to heat it up a little, that seems to be the last ditch effort that usually works for me
Old Sep 24, 2003 | 10:22 PM
cruzersi99's Avatar
Default Re: Header bolt hatred.... (98ITR#0020)
Craftsmen kit -$20 worth of
Gator Grip - $20 worth of
Nothing will work. I'm giving up... I hate cars right now
Old Sep 24, 2003 | 10:27 PM
Phoenix_ITR's Avatar
did you try putting the other bolts back in and then breaking the stubborn nut loose? it could be that if you removed all the other bolts/studs, the header might be putting pressure on that one nut, making it hard to remove.
-tony
Old Sep 25, 2003 | 01:31 AM
LSvtec03's Avatar
Default Re: Header bolt hatred.... (delinquent)
http://www.mitools.com
Old Sep 25, 2003 | 01:37 AM
1OPTION's Avatar
Its all about speed. Gotta have the rite technique or your up the river.
Old Sep 25, 2003 | 06:42 AM
cruzersi99's Avatar
This was actually the first bolt. LOL
I then loosened all the others without problem and tried again. I have since tightened them all up again. Still no luck.
I think my only resort is to take it to a shop and have them laugh at me, and the proceed to charge me for an hours shop time or more
Old Sep 25, 2003 | 06:49 AM
Chris N's Avatar
Hammer on the wratchet, long breaker bar, etc. Force is the only way. Lots of it.
Old Sep 25, 2003 | 07:27 AM
cruzersi99's Avatar
Default Re: Header bolt hatred.... (Chris N)
Anybody know the Part # or Thread/Pitch of this bolt (Upper left header bolt).
Just called my local dealership and they want $6 and I have to wait two days. What a joke.
Old Sep 25, 2003 | 08:07 AM
JoshRambo's Avatar
I take it you got my header then?
Everything cool with it?
Old Sep 25, 2003 | 11:11 AM
cruzersi99's Avatar
Default Re: Header bolt hatred.... (Gravity)
Looks good, wish I could put it on
Old Sep 25, 2003 | 11:27 AM
tnord's Avatar
Default Re: Header bolt hatred.... (sackdz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sackdz &raquo;</TD></TR><TR><TD CLASS="quote">Use a 6pt socket, not 12.</TD></TR></TABLE>
+a real big breaker bar
Old Sep 25, 2003 | 11:30 AM
AssPenny's Avatar
Default Re: Header bolt hatred.... (tnord)
Liquid wrench
Old Sep 25, 2003 | 11:49 AM
Willard's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Philly_NBP_R &raquo;</TD></TR><TR><TD CLASS="quote">like AeroCroil if you can find it</TD></TR></TABLE>
AeroKroil
https://rodney.concentric.net/...u.htm
Old Sep 25, 2003 | 01:48 PM
Chris N's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tnord &raquo;</TD></TR><TR><TD CLASS="quote">
+a real big breaker bar</TD></TR></TABLE>
+ stand on the valve cover and use your foot....
Old Sep 25, 2003 | 02:21 PM
Rob Dizzle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris N &raquo;</TD></TR><TR><TD CLASS="quote">
+ stand on the valve cover and use your foot....</TD></TR></TABLE>
yeah, and what have you tried before so far?
Old Sep 25, 2003 | 02:29 PM
00 FBP ItR's Avatar
Default Re: Header bolt hatred.... (AssPenny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AssPenny &raquo;</TD></TR><TR><TD CLASS="quote">Liquid wrench </TD></TR></TABLE>
Used it on exhuast bolts.. they came off w/ ease.
Old Sep 25, 2003 | 03:44 PM
strepto's Avatar
Default Re: Header bolt hatred.... (00 FBP ItR)
Tough..
Next time..
http://buy1.snapon.com/catalog...talog
Old Sep 25, 2003 | 04:52 PM
ITR764's Avatar
Default Re: Header bolt hatred.... (Willard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Willard &raquo;</TD></TR><TR><TD CLASS="quote">
AeroKroil
https://rodney.concentric.net/...u.htm</TD></TR></TABLE>
kroil is tha ****!!!!
