Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Has any one Pulled the ABS system..
Old Sep 24, 2003 | 04:34 PM
Outsane's Avatar
Default Has any one Pulled the ABS system..
I did do a search..
Building a car for h3, I think. I forget which class.. its a 95 GSR.
the ABS has never worked on this car, and we want to pull it. I thought I would ask you guys before we had brake fluid every where.
Old Sep 24, 2003 | 05:04 PM
.RJ's Avatar
.RJ
Default Re: Has any one Pulled the ABS system.. (Outsane)
You could swap in non-ABS RS-model M/C and lines.
Old Sep 24, 2003 | 08:13 PM
Honda318dx's Avatar
Default Re: Has any one Pulled the ABS system.. (.RJ)
or just run your own lines, like I did, all you need is a flair tool, maybe a pipe bender.. wasn't to hard, no leaks yet, and have a prop valve.. Also takes more weight of the nose of the car..
Old Sep 25, 2003 | 07:10 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
i removed the abs out of my 94 civic. frankly, with the brakes that were on the car, the abs proportioning just sucked. the car is soo much faster without it.
Old Sep 25, 2003 | 08:09 AM
SpiceyRice's Avatar
Default Re: Has any one Pulled the ABS system.. (rodney)
Ditto, I didn't use the ITR ABS when converting to an EG. We had to make custom brake lines (or you could use the lines from a non-abs model of your car).
The custom lines didn't take long to make -- so it shouldn't cost too much to have someone in the business make them for you.
First couple of times I hard braked in the EG, I locked up the wheels, but after a few days I got used to it and I don't lockup anymore.
I do get people telling me I'm locking up my inside rear during slow turns on track -- something I don't think would be an issue if I had ABS. I haven't seen any unusual wear on the rears because of it tho. - no abs
Old Sep 28, 2003 | 06:35 PM
migs's Avatar
Default Re: Has any one Pulled the ABS system.. (SpiceyRice)
I removed ABS from my 95 GSR. I had to use the RS prop valve, all four RS front brake lines and the RS MC and BB. It took me a total of 2.5hours.
Vcastro
Oct 13, 2006 08:46 AM
rochnyteg
Jul 15, 2004 12:49 AM
dchi_t
Mar 10, 2003 03:36 AM
oioioi
Jan 23, 2003 02:56 PM
