o2 sensor question
I just change my ATF then I notice the connector between O2 sensor wire and the
o2 sensor( the one at the end of the header and b4 the cat) is burned due to the
header ( I installed the DC sport header like a month ago).
The connector is made of plastic so it melted since it's touching the header
to the shop that install the header) but the wire is fine
My CEL is not light up , question is : is it ok leaving the connector like that ?
and what happen usually if the O2 sensor at the header not working ?
Thx for the answer
to the shop that install the header) but the wire is fineMy CEL is not light up , question is : is it ok leaving the connector like that ?
Thx for the answer
Depending on how badly melted the connector is I would replace it. At lease I would zip tie it out of the way. You could go to a junkyard splice in a new connector or you could just hard wire the o2 sensor around the melted connector. But I would only do that if the connector was badly destroyed.
MainStreamHonda
Aug 9, 2011 09:36 AM
mugenpovver
Feb 16, 2008 12:56 PM
newBcrxer
Jun 21, 2004 08:46 AM
