Installing a 1998 H22 in a 1992 Prelude Si
Hey guys, what all will I need to change on this motor to make it work in my car?
I plan on using a OBDI ECU. Will I need to change the distributor?? If so...can I use my H23 one??
Thanks
Thanks
You can use your H23 Dis. Use your H23 harness, and use add the Vtec wires. Umm you need OBDI injectors and ECU. Also use all you H23 mounts and you need to use the H23 VSS, the whole thing not just the sensor. Reuse your PS pump and bracket, you'll need to cut the back of the bracket off for it to fit or go find a 4th gen bracket, reuse you A/C. TB use the one from the 98 and just extend your MAP sensor plug to fit. I think thats just about it.
I did the same thing myself.
