HEADERS???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Russ1414B16a1seeya »</TD></TR><TR><TD CLASS="quote">Which is better DC sports 4-2-1 header or DC sports 4-1 header???</TD></TR></TABLE>
Which ever one fits in your car now....
4-1 has more ground clearance issues also, and how often do you spend at 6,500 rpm+ that where the 4-1 out does the 4-2-1, below 6,500 the 4-2-1 makes more power.
Be realistic if you are street driven miles, the 4-2-1 is best choice, at drage strip or road course then just maybe the 4-1 has a slight edge. but at the expense of lower rpm power.
what about o2 sensor placement on those headers,i have a b16 with 2 sensors do they make headers with 2 places for them?btw i like dc sports 4-2-1 1 peice but i cant see any sensors bungs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GreenMachineRex »</TD></TR><TR><TD CLASS="quote">ok HEADER!!!!
and 4-1 will be a bitch to install</TD></TR></TABLE>
Actually, you are wrong. It is a set of head PIPES. Back in the day they started to call them headers for short. Multiple head pipes = a set of headers. you dont where a pant, or a short on your legs, do you?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by azroth »</TD></TR><TR><TD CLASS="quote">
well put my friend
how much are you looking to spend and does your car have clearance for a 4-1? w/ a stock crossmember unless you bang it, the 4-1 headers arent going to fit
well put my friend
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GreenMachineRex »</TD></TR><TR><TD CLASS="quote">and 4-1 will be a bitch to install</TD></TR></TABLE>
not really......
not really......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spaceman »</TD></TR><TR><TD CLASS="quote">what about o2 sensor placement on those headers,i have a b16 with 2 sensors do they make headers with 2 places for them?btw i like dc sports 4-2-1 1 peice but i cant see any sensors bungs</TD></TR></TABLE>
you'll need an exhaust shop to fab them in for ya
not the same. it's a pair of pants........ not a pair of headers.
with your reasoning, all the manufacturers are completely wrong when they label their product as a 4-1 header, etc...... headers are for V-6s, V-8s, hence a pair, or more.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicDXdude »</TD></TR><TR><TD CLASS="quote">dont get stainless they will look like crap after a month or so. get ceramic and it will look brand new forever.</TD></TR></TABLE>
Wrong
Stainless may Discolor from Heat, but will Never Rust like the Ceramic does after Extended use. I am running a DC 4-2-1 Ceramic Header, Heat Wrapped and POR-15 Coated.....Helps keep underhood Temps cool and its still Nice and Clean with 2.5 Years of use.
Mike
Wrong
Mike
you are wrong. i had a 4-2-1 Stainless HP racing header on my B18. guess what... it was rusting from years of use. they discolor first, then they turn burnt black, and look like absolute ****. I had a dc 4-2-1 on my d16z6 for a year and it still looked like the day i installed it. My friend has a Del Sol VTEC with a DC 4-2-1 1 piece ceramic.. he's had it for almost 3 years and it still looks new. All the stainless headers i've seen that have been used look like absolute **** after a couple months.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicDXdude »</TD></TR><TR><TD CLASS="quote">you are wrong.</TD></TR></TABLE>
Nope, Try again.
Ever seen a DC Sports Stainless header after years of use? Looks perfect, with Discoloration....Obviously your experience has been limited to Low Quality parts when it comes to Stainless....Possibly cause it was just a Stainless "Look" Header.
Thanks for playing!
Mike
Modified by 88ZC_REX at 3:33 AM 9/25/2003
Nope, Try again.
Thanks for playing!
Mike
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88ZC_REX »</TD></TR><TR><TD CLASS="quote">Wrong, stainless may Discolor from Heat, but will Never Rust like the Ceramic does after Extended use. </TD></TR></TABLE>
Raises glass in air (
) This contestant has definatly done his home work. Cerminic does rust in record time if not taken care of. Stainless due to it's nature changes color with heat with shades of purple, blue, green and some others. Everthing has a trade off. Just like your decision to use a 4-1 or 4-2-1. I suggest you read carefully about your choice of headers. Or find people who have both kinds and ask them how it changed the car. For each one typically has 2 difference charastics. Each is disigned for 2 different purposes. Only one catch to stainless not rushing. If you use regular weld or a non steel weld to modify the header. Watch it rust.
i was looking at some 4-2-1 pcs and it looks like there is an accomodation for an o2 sensor at the end of the pipe
Wrong
Mike
not to mention that SS headers are higher quality metal, they will not dent near as easy as a ceramic coated header if you accidentally scrape
Wrong
Mike
