Ground Control Instructions
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Renegade »</TD></TR><TR><TD CLASS="quote">just don't put the spring upside down?</TD></TR></TABLE>
lol, seriously, i had to go back and do it all over again when i found out i couldnt read the writing on my springs....
does the set of 4 GC usually come with 4 big urethane washers that go on top of hte spring??? Do those replace the stock units?
i don't remember getting urethane washers with mine, everytime I take them out i never see any type of washer, only washers are the ones for the shock on the strut mount.
sorry I meant shock mount...
Modified by Renegade at 6:12 AM 9/25/2003
from what i see, the stock rubber moldings that fits under the upper hat can be reused for spring rates smaller than 450lb/inch and 7" or 8", where the coil diameter is small enough that they still fit in the rubber molding. otherwise, they should give you the flat urethane replacement. it doesnt matter which you use.
