4th gen with 5 lug conversion
Old Sep 24, 2003 | 01:58 AM
n1_ek's Avatar
* B A N N E D *
Default 4th gen with 5 lug conversion
does anyone know on how to do it? What parts etc is needed to do the swap. Ive seen one car pic of a 4th gen prelude with 5 lug conversion and thats what i wanna do. Wondering if 4th gens can use the 5th gen rotor/whole set up. Just seeing if anyone has a write up on this cuz i cant find **** on it. thanks for any help
Old Sep 24, 2003 | 05:02 AM
satan_srv's Avatar
Default Re: 4th gen with 5 lug conversion (ryan819)
I'll have mine done on Friday. What model do you have now? It's pretty easy.
- front 5th gen knuckle assembly/spindle/hub/rotor/abs sensor (caliper if you don't already have VTEC brakes)
- Rear 5th gen spindle/hub/rotor abs sensor (all 4th gen rears are the same so I don't think you need the caliper.
- 5 bolt rims.
Old Sep 24, 2003 | 06:39 AM
NirVTEC's Avatar
Default Re: 4th gen with 5 lug conversion (satan_srv)
It has been done but I just am not sure why!?
The only thing I would see as an advantage is wheel selection.
Satan, can you post estimated cost for this swap?(parts)
Old Sep 24, 2003 | 10:05 AM
Fly1865's Avatar
Default Re: 4th gen with 5 lug conversion (NirVTECn2o)
https://honda-tech.com/zerothread?id=552938
Old Sep 24, 2003 | 10:44 AM
satan_srv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NirVTECn2o &raquo;</TD></TR><TR><TD CLASS="quote">It has been done but I just am not sure why!?
Satan, can you post estimated cost for this swap?(parts)</TD></TR></TABLE>
I did it to get new wheel bearings mainly, and newer abs sensors
I got all the pieces with pads and rotors with Base rims and RE92s for $400 but I doubt anyone will get near that price. It's like $1000 if you don't look around.
Old Sep 24, 2003 | 12:57 PM
NirVTEC's Avatar
So $1000 to have better wheel selection?!?!
I could maybe see some hardcore racers doing it because there's obviously a reason that the ITR has 5 and the GSR has 4.
That just seems like a waste for just more wheels to choose from.
Old Sep 24, 2003 | 01:12 PM
n1_ek's Avatar
* B A N N E D *
Default thanks
hey guys thanks for the help. Well i want it cuz i have the 92 s model rotors which is smaller. i want to upgrade to the 5th gen brakes. wouldnt that give me more braking power? also its a new look and you dont see it much. Where did you guys find these parts? junkyard? Its kind of rare to find someone selling their 5th gen parts. Im goin to search around if i can find all the necessary parts. nice pictures of all the 4th gens with 5 lugs. looks sick
Old Sep 24, 2003 | 01:21 PM
NirVTEC's Avatar
Default Re: thanks (ryan819)
Wouldn't you just be able to swap 4g VTEC brakes on their?
I would also consider doing an NSX front swap before I spent $1000 on the 5lug swap.
Old Sep 24, 2003 | 02:32 PM
str8rcn's Avatar
Default Re: thanks (NirVTECn2o)
Correct me if im wrong but arent the 5th gen fronts and ITR fronts the same brakes.If so that would open up a whole new section of brakes and rims.
Old Sep 24, 2003 | 02:48 PM
satan_srv's Avatar
Default Re: thanks (str8rcn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by str8rcn &raquo;</TD></TR><TR><TD CLASS="quote">Correct me if im wrong but arent the 5th gen fronts and ITR fronts the same brakes.If so that would open up a whole new section of brakes and rims.</TD></TR></TABLE>
No they aen't.
If you have VTEC calipers already you don't need to disconnect/bleed the brake lines.
Old Sep 24, 2003 | 07:58 PM
slowone's Avatar
Default Re: thanks (satan_srv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv &raquo;</TD></TR><TR><TD CLASS="quote">
No they aen't.
If you have VTEC calipers already you don't need to disconnect/bleed the brake lines.</TD></TR></TABLE>i've done this swap and put new rotors and pads as well. i pushed the brake pistons back to accept the new pads. but, now when i drive the brakes make a scraping sound, like they're partially engaged. i've asked for help on this subject a couple times on here and everyone was just a dick to me. you seem pretty knowledgeable, do you know what could be wrong? thanks.
Old Sep 24, 2003 | 09:05 PM
n1_ek's Avatar
* B A N N E D *
newb question. if i have the whole 5th gen swap. and want to buy a camber kit like ingalls etc. i would have to purcahse it for the 5th gen instead of teh fourth. ill do my research but i jstu want a quick answer. thanks
Old Sep 25, 2003 | 07:04 AM
VividBlueFit's Avatar
for simple ease of installation and to avoid as much downtime as possible
--- use the entire 5th gen front knuckle. ive have heard you can use the 4th gen knuckle and just buy the 5th gen wheel bearings, but they must be pressed in, which unless you have access to a press, you will not be able to do this yourself
anyway....
what you need:
FRONT
5th gen front knuckles (or bearings if you have access to a press, but dont quote me on this as this is not how i did it, someone that did told me it works)
5th gen front hubs
rotors for 5th gen (OEM new or used, or your choice of aftermarket 97+ rotors)
4th or 5th gen calipers, if using 4th gen calipers they must be vtec calipers
REAR
5th gen rear hubs
5th gen rear rotors
5th gen rear spindles (new or used, if purchased used they may come with the rear knuckles, in which case just unbolt them from the knuckles and swap them with the ones currently on your car)
the above will give you everything you need to get those pimp 5lug wheels on your car
additional notes:
---4th gen rear ABS sensors will not bolt directly to the 5th gen spindles, currently my damn abs light is glowing bright yellow. so if you can get the abs sensors with your parts, do so. i will need to source some as these are expensive parts from honda, the teeth on the hubs for the abs look identical, and the spindles are the same shape its just that the holes for the bolts for the sensor are in a different location. im considering some jbweld so that i dont have to use the bolts, it looks like it would work, but this could really suck if you needed new spindles and werent able to get the abs sensors off, you would have to buy new sensors.
---oh and dont forget to go pick up 4 more lug nuts honda wants 7 bucks a piece so i just bought a set of wheel locks.
found this on another site,
Old Sep 25, 2003 | 07:27 AM
slowone's Avatar
Default Re: (SpoolBlude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoolBlude &raquo;</TD></TR><TR><TD CLASS="quote">for simple ease of installation and to avoid as much downtime as possible
anyway....
what you need:
FRONT
5th gen front hubs
REAR
5th gen rear hubs
5th gen rear rotors
additional notes:
found this on another site, </TD></TR></TABLE>which part exactly is the spindle? will i still need the abs sensors if i am removing my abs?
ImPuLsIvE
Mar 1, 2006 01:42 AM
2point6
Aug 30, 2004 05:37 PM
RUBZERK
Mar 4, 2004 07:48 AM
Gennady
Mar 26, 2003 07:59 PM
