peak and hold resistor box wiring, why can't you...
Old Sep 23, 2003 | 10:13 PM
cornhusker's Avatar
Default peak and hold resistor box wiring, why can't you...
i was thinking about the install tomorrow. and i was thinking, once you check for continuity at the distribution plug and figure out which wires go to the injectors, why can't you just use one radio shack resistor and tie all four lines together to each side of the resistor? (i know kinda confusing, so here are two diagrams of what i am talking about, picture is worth a thousand words)
Old Sep 23, 2003 | 10:45 PM
2SLO's Avatar
Default Re: peak and hold resistor box wiring, why can't you... (cornhusker)
i think it would throw off something or other.
Old Sep 24, 2003 | 04:09 AM
Davep's Avatar
No this will not work.
Old Sep 24, 2003 | 05:27 AM
Charlie Moua's Avatar
Default Re: peak and hold resistor box wiring, why can't you... (Davep)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Davep &raquo;</TD></TR><TR><TD CLASS="quote">No this will not work. </TD></TR></TABLE>
why the **** not?... damn i hate when poeple post answers like this. please educate us all an explain it atleast.
Old Sep 24, 2003 | 05:31 AM
Tinker219's Avatar
Default Re: peak and hold resistor box wiring, why can't you... (Charlie Moua)
Ive thought about that too. Each injector fires SEPERATELY. THe yellow wires are the power wires, and colored wires are grounds, that the ECU grounds out when triggered to.
So, no matter what, all the black/yellow wires are hot, injector firing or not, so no matter what, i dont see anything "******* up".
I say ITLL WORK. Maybe run two resistors instead of one? Itll help the load. that the resistor will see a little bit...
Old Sep 24, 2003 | 05:40 AM
Foozball26's Avatar
Default Re: peak and hold resistor box wiring, why can't you... (Tinker219)
as long as the proper resistance is maintained, i foresee no problem with it.
think about it this way, when most people wire in a resistor box, they take 4 wires and only use ONE to power the resistor box.
so it will work in theory
Old Sep 24, 2003 | 05:43 AM
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Charlie Moua &raquo;</TD></TR><TR><TD CLASS="quote">
why the **** not?... damn i hate when poeple post answers like this. please educate us all an explain it atleast.</TD></TR></TABLE>
Yeah, I have to agree here.
I don't see why this wouldn't work. Although the Honda Resistor box is 6ohms not 10. Also, a resistor box keeps the resistors cool for long life.
Old Sep 24, 2003 | 06:06 AM
xci_ed6's Avatar
Default Re: peak and hold resistor box wiring, why can't you... (ladysman)
with the overlap of the injector pulses your Vdrop across the resistor will change. Use 4, if you want it to work right.
-Dustin
eL_cArLos
Aug 17, 2008 07:11 AM
AbitAvenger
May 1, 2006 10:03 AM
VTECJUN
Dec 13, 2005 11:44 AM
Nextelbuddy
Dec 5, 2003 10:13 AM
2k1_ITR_0736
Jul 1, 2003 02:45 AM
