can't go above 3500 rpm
Old Sep 23, 2003 | 08:07 PM
GuyInASpeedo's Avatar
Default can't go above 3500 rpm
okay, my friend just replaced his distributor cap and now he can't go past 3500 rpm. We reset the ECU, checked the firing order, neither worked, what could be the culprit and how can it be fixed?
Thanks in advance
Old Sep 23, 2003 | 09:27 PM
civickiller's Avatar
Default Re: can't go above 3500 rpm (GuyInASpeedo)
whats the code hes getting ?
Old Sep 23, 2003 | 09:40 PM
Neptune's Avatar
What happens at 3500 RPM?
Old Sep 23, 2003 | 09:53 PM
quiambao1180's Avatar
is the check engine light on??? if so a friend of mine had the same problem... one of the connectors were loose check all your connections aropund your t/b...
Old Sep 23, 2003 | 10:15 PM
Default Re: can't go above 3500 rpm (Neptune)
at 3500 rpm it just bounces even if he has it floored it hits 3500, drops to about 3000 and goes back and forth like that
Old Sep 23, 2003 | 10:18 PM
jdmcivicferio's Avatar
Default Re: can't go above 3500 rpm (quiambao1180)
if your car is cutting out at 3500 it is running in a limp mode, it should be throwing a code, check your ecu to see what code it is flashing.
Old Sep 23, 2003 | 10:22 PM
Default Re: can't go above 3500 rpm (jdmcivicferio)
sorry if I sound like an idiot, but how do I check ECU codes on an 89??
Old Sep 23, 2003 | 10:30 PM
bossman032's Avatar
fuel injector or dizzy problems
enlight me!!! tomorrow
Old Sep 23, 2003 | 10:32 PM
Default Re: can't go above 3500 rpm (bossman032)
ummm...what?
Old Sep 23, 2003 | 10:39 PM
k, n/m I figured out how to check the codes...Any other ideas on what it could be?
Old Sep 24, 2003 | 12:05 AM
so what code is he getting ?
Old Sep 24, 2003 | 04:59 AM
markedOO1's Avatar
Default Re: can't go above 3500 rpm (civickiller)
..igniter?
Old Sep 24, 2003 | 06:06 AM
Phatwhippin_CRX's Avatar
Default Re: can't go above 3500 rpm (markedOO1)
definitely sounds like it......
Old Sep 24, 2003 | 06:25 AM
markedOO1's Avatar
Default Re: can't go above 3500 rpm (Phatwhippin_CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phatwhippin_CRX &raquo;</TD></TR><TR><TD CLASS="quote">definitely sounds like it...... </TD></TR></TABLE>
..and whatta you know?
Old Sep 24, 2003 | 07:34 AM
because a shitty cap and rotor left me stranded on the side of the PA turnpike 2 years ago!
Godspeedmj
20
Aug 12, 2010 01:22 PM
vteck1ck
Dec 27, 2009 09:16 PM
duthie14
Apr 4, 2008 10:27 AM
DAYUIZ
Apr 24, 2003 03:48 AM
GSRdriver
Dec 25, 2001 12:48 AM
