can you put a TYPE R....
Old Aug 24, 2001 | 09:06 AM
Ladies Man's Avatar
New User
Default can you put a TYPE R....
can you put a type r rear upper trunkbrace in a civic??? not the upper strut bar but trunk bar that connects between the tail lights on the chassiss
I plan on selling mine to a buddie with a EK
Old Aug 24, 2001 | 09:30 AM
H-PIMP's Avatar
Default Re: can you put a TYPE R.... (Ladies Man)
NO.
Old Aug 24, 2001 | 09:32 AM
RyanR's Avatar
Default Re: can you put a TYPE R.... (H-PIMP)
Yes. Just drill holes, get some nuts, bolts and large washers and your set.
Old Aug 24, 2001 | 09:33 AM
Rhetoric's Avatar
I'm pretty sure you can modify slightly. Just drill the holes screw it in make sure to measure before cutting the panel trim.
Old Aug 24, 2001 | 11:54 AM
Dropspeed's Avatar
Default Re: can you put a TYPE R.... (G S R)
NO! You can't do it. Even with a nut and bolt the metal in that area is not reinforced like it is in the ITR
Mattj
Old Aug 24, 2001 | 11:57 AM
6SPD_EK's Avatar
Default Re: can you put a TYPE R.... (Dropspeed)
what about in a GSR? sedan?
Old Aug 24, 2001 | 12:22 PM
Cosworth's Avatar
Default Re: can you put a TYPE R.... (2000-4DRGSR)
The bar won't be effective if you drill new holes. What I found interesting is that you "might" be able to put the bar on a 96-'00 Civic hatch. Place the bar where the bolts for the rear-bumper is. It should theoretically fit... never tried it.
Old Aug 24, 2001 | 02:48 PM
ITR 00-1567's Avatar
New User
I think Bennen (or Bennin?) makes a "strong bar" for GSR's and cretain Civics that bolts in between the taillights. I think Diablo Autosports (who have banner adds on this sight) carries Bennen.
Ian
Old Aug 24, 2001 | 03:09 PM
Champ#358's Avatar
Default Re: can you put a TYPE R.... (ITR 00-1567)
It's Benen Industries, I used to hang out with Benen when we were in high school.
Old Aug 24, 2001 | 03:39 PM
Conechaser's Avatar
Default Re: can you put a TYPE R.... (Champ#358)
It will bolt into any Integra, w/ no mods (well you have to cut the little plastic cut outs out, but they are marked for you)
Mccormick009
Nov 30, 2014 12:05 PM
Em1_CoupeR
Suspension & Brakes
Nov 26, 2009 06:26 PM
turnsignalandy
Oct 28, 2006 06:53 PM
erasable180
Nov 24, 2005 06:17 PM
