OBDII ...is there anything to do with that ??
Old Aug 24, 2001 | 09:04 AM
JinMTVT's Avatar
New User
Default OBDII ...is there anything to do with that ??
is there anyway to reprogram theese computers at all ?
like raising limiter...extending maps ??
what happens when u raise the limiter. .is there maps for more rpm than the stock limiter ? does it extrapolate ?
what is needed for obd1 swap ??
tanx
Old Aug 24, 2001 | 09:10 AM
brian b's Avatar
New User
Default Re: OBDII ...is there anything to do with that ?? (JinMTVT)
odb-ii requires about 750 worth of parts to burn the rom, and its about 100 bucks per chip.. its alot cheaper to go with odb-i and hondata for tuning..
Old Aug 24, 2001 | 09:48 AM
JinMTVT's Avatar
New User
Default Re: OBDII ...is there anything to do with that ?? (brian b)
ok
cool
so it's feseable ??
but who got the parts to burn it ?
where to get that done ?
wehre to buy the parts ??
tahnks
Old Aug 24, 2001 | 10:32 AM
MysteryWagon's Avatar
I wish I had the soft ware to do ecu programing. That would be the ****
Old Aug 24, 2001 | 07:14 PM
HXMan's Avatar
OBD1 conversion requires a convertor harness.
I belive that if you have an early OBD2 ECU (96-98) you can get another program installed by Hondata, but it will cost around $200 dollars each time cuz a new chip must be installed with every change.
Old Aug 24, 2001 | 07:20 PM
BreakStuff's Avatar
New User
Default Re: OBDII ...is there anything to do with that ?? (HXMan)
The "Honda" programable ECU is just around the corner and has been long awaited..
Hyundai's been doing it for years..
Old Aug 24, 2001 | 10:27 PM
JinMTVT's Avatar
New User
Default Re: OBDII ...is there anything to do with that ?? (BreakStuff)
then how to get proper maps and stuff on the first time ??
eheh
200$ each time ?
where to get the stuff that can be used to reprog the ecu ?
i wouldn't mind buying it..
then i could offer u all OBDII progs
eheh
how much is worth the obd1 converter harness ?
is it worth it?
Old Aug 25, 2001 | 05:09 PM
HXMan's Avatar
check out http://www.hondata.com
Should answer lots of your qusetions.
Hey JinMTVT....you were on SHO way back right? I remember you.
Old Aug 25, 2001 | 06:36 PM
DirtyLude's Avatar
http://www.hondaprelude.to/articles/inst-e6k.html
Old Aug 25, 2001 | 06:46 PM
JinMTVT's Avatar
New User
eheh
yeah i was
i was the POST MASTER! before it crashed
eheh
Old Aug 25, 2001 | 06:49 PM
JohnX6's Avatar
If you have a 96-98 Honda/Acura you can get a Harness converter from Skunk2 Racing...I did that and i'm running on the Skunk2 OBD1 Chipped ECU.....that was the easiest way in my book...there's also Harness for 99-00 Civic/Integra Too
Zfracing
Mar 20, 2017 01:41 PM
BlackRocket
Jul 10, 2007 03:37 PM
yellowbuffalo
Oct 28, 2003 07:11 AM
beaterman
Oct 6, 2003 08:42 AM
