Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
Taking out CL front and back speakers?
Old Sep 23, 2003 | 12:45 PM
technine's Avatar
Default Taking out CL front and back speakers?
I am having a problem taking out the rear speakers and front speakers on my 97 CL. I don't know if I should pop off the grills on the speakers or access the proper screws for them. Anyone know how to do it? Don't want to scratch the interiour all up if I don't have to.
And is there any kit that is made to replace the bottom consol pocket with something else, like a EQ or something like that?
TIA
Old Sep 30, 2003 | 12:18 PM
technine's Avatar
Default Re: Taking out CL front and back speakers? (technine)
TT what a joke
Old Sep 30, 2003 | 09:26 PM
MisterB's Avatar
i did mine along time ago... back speakers i cant really rememper but i think the screan has some clips holding it down. then you remove the speaker from the top. im not too sure of this i would go look but my CL is at the boddy shop sorry.
front speaker you have to take off the door panals or drill a hole to access the last screw
Old Oct 1, 2003 | 08:01 AM
TEXN3's Avatar
Default Re: Taking out CL front and back speakers? (MisterB)
you can get a honda eq to fit in the bottom pocket. but it uses the same plug as the cd changer. so, if you have a cd changer or other accessorie hooked up, then it won't be functional. i however put one in just to fill up space. i like radio buttons!!
Old Oct 2, 2003 | 03:34 PM
technine's Avatar
You sure about the last screw on the front?? That seems like an awful amount of work just for 1 screw.
Old Oct 2, 2003 | 04:56 PM
MisterB's Avatar
im pretty sure there is 3 screws that hold the front speaker in the door. just pop off the cover and you will be able to see for sure.
Old Oct 3, 2003 | 08:57 PM
d98clturbo's Avatar
you have to take off the door panel to get to the front speakers...you have to take off the rear dash...take out the rear seatback then take out the brake light then lift the back dash up & out...then unscrew the the speakers
Old Oct 18, 2003 | 06:19 PM
ambiguous's Avatar
for the fronts you need to take off the door panels completely; for the rear, there should be four screws that hold the grills/covers from underneath accessed from the trunk and then you can get the speakers from the top
RealGingerHacks
Honda Civic (2001 - 2005)
10
Mar 24, 2019 05:32 AM
Scotty Dosent Know
Audio / Security / Video
Mar 14, 2009 09:19 AM
Whats_the_w0rd
Sep 10, 2006 12:24 PM
tossnupweight
Jun 12, 2003 05:04 PM
