B16 Head on B18 Block
I have searched for the answer to this question, but have found nothing...
I am going to install a B16 (Vtec) head on my B18 (Vtec) block. Does anyone know if I also have to install a B16 intake manifold and throttle body? I think the B18 manifold/throttlebody will bolt up, but I am not 100% sure, and I don't want to waste my time to put the B16 head on, if I have to take it off because I need to replace other parts...
putting a b16 head on a gsr will not give u more compression, it will do the oppisite!you will be lowering the compression. Do some more research b4 u do this mod !! and that b16 mani will not bolt up to a gsr block either. If you want to raise the compression on a GSR you will either have to chage the head gasket get teh head milled or replace the pistion with some p30's or some pct's!
