205/40 - 16
yea, i have that size right now, but i can't slam my car w/o rubbing. I am thinking that getting the 205/40 and rolling my fenders will do the job. Does anybody have real life pictures of this size tire on integras?
my rims have a +35mm offset, and I like to really lower the car, like 3.5 inches. With no negative camber the tires are basically touching the fenders at a height like that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bolivianstrtwpn »</TD></TR><TR><TD CLASS="quote">...and I like to really lower the car, like 3.5 inches. With no negative camber the tires are basically touching the fenders at a height like that.</TD></TR></TABLE>
Why the hell would you want to lower it that far?!?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wall of tvs »</TD></TR><TR><TD CLASS="quote">
Because it looks good
</TD></TR></TABLE>Because it looks good
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bolivianstrtwpn »</TD></TR><TR><TD CLASS="quote">my rims have a +35mm offset, and I like to really lower the car, like 3.5 inches. With no negative camber the tires are basically touching the fenders at a height like that.</TD></TR></TABLE>
Set the camber to about -1.5 to -1.8 or so. You can easily run that and have little to no tire wear problems, if the toe is set exactly to factory specs, and you rotate tires often. That might give you a little extra fender clearance.
I guess I'm not a fan of the super-dropped look with the tires tucked inside the fenders -- I'm a fan of a "1 finger width" gap between the tire and fender.
performance > appearance, IMHO.
If you dig it, more power to you
</TD></TR></TABLE>I guess I'm not a fan of the super-dropped look with the tires tucked inside the fenders -- I'm a fan of a "1 finger width" gap between the tire and fender.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bolivianstrtwpn »</TD></TR><TR><TD CLASS="quote"> and I like to really lower the car, like 3.5 inches. With no negative camber the tires are basically touching the fenders at a height like that.</TD></TR></TABLE>
That will look like **** and handle like ****, but hey to each his own.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quikB18B »</TD></TR><TR><TD CLASS="quote">
That will look like **** and handle like ****, but hey to each his own.</TD></TR></TABLE>
Thats why they invented coilovers bud, you get to move the height of your car up and down as much as you please. It's a really interesting concept, who would have ever thought you could change the ride height of your car??!?@? (sarcasm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 »</TD></TR><TR><TD CLASS="quote">
Set the camber to about -1.5 to -1.8 or so. You can easily run that and have little to no tire wear problems, if the toe is set exactly to factory specs, and you rotate tires often. That might give you a little extra fender clearance.</TD></TR></TABLE>
thanks for the info, im going to try that out
I have that size tire with c8's on my integra. I bent one rim when the were on a 89 hatchback. I think it was cause there were not enough cushion with 40 series tires. thewrefor making it easy to bend lightweight rims.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4potnick »</TD></TR><TR><TD CLASS="quote">I have that size tire with c8's on my integra. I bent one rim when the were on a 89 hatchback. I think it was cause there were not enough cushion with 40 series tires. thewrefor making it easy to bend lightweight rims.</TD></TR></TABLE>
whoa, thanks alot, maybe i will be staying away from these size tires
If you adjust coilover height w/o getting an alignment, you will eat your tires to pieces. When the ride height changes, both camber AND toe-in are affected. You should set it to the height you like (possibly even corner-weight the car to get the most out of it), get an alignment, and leave it there. If you need to raise it for winter, get it aligned again for that. It's usually a good idea to get the alignment checked about every 6 months or so anyway, especially if you're like me and running -2.3 deg. camber in front w/o camber kit.
</TD></TR></TABLE>If you adjust coilover height w/o getting an alignment, you will eat your tires to pieces. When the ride height changes, both camber AND toe-in are affected. You should set it to the height you like (possibly even corner-weight the car to get the most out of it), get an alignment, and leave it there. If you need to raise it for winter, get it aligned again for that. It's usually a good idea to get the alignment checked about every 6 months or so anyway, especially if you're like me and running -2.3 deg. camber in front w/o camber kit.
Drewsgotshoes
Feb 18, 2017 08:30 PM
iPaul05
Honda Civic (2001 - 2005)
15
Apr 12, 2007 03:34 AM
