which cams work best for ITBs?
What cam profil works best on B18C5 with 12.5:1 cr and TWM ITBs? Someone has experience. We tried JUN III and had less power than with oem ITR cams. We tried 2 hours different cam settings with the gears. We using haltech e6k ECU.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by austrian type-R »</TD></TR><TR><TD CLASS="quote"> We tried JUN III and had less power than with oem ITR cams. We tried 2 hours different cam settings with the gears. We using haltech e6k ECU.</TD></TR></TABLE>
I find that hard to believe. Tuning problem perhaps....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kengs »</TD></TR><TR><TD CLASS="quote">Christian, you should IM Supertwinz
i believe that Jonh was running skunk stage 3 , unless he change them to something else (which i wouldnt be surprise
</TD></TR></TABLE>i believe that Jonh was running skunk stage 3 , unless he change them to something else (which i wouldnt be surprise
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sgT »</TD></TR><TR><TD CLASS="quote">
I find that hard to believe. Tuning problem perhaps....</TD></TR></TABLE>
me 2
me 2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by len »</TD></TR><TR><TD CLASS="quote">VTEC Killers? Longer duration cams??? I dunno.</TD></TR></TABLE>
if longer duration would work the best (which im not sure ) the Spec D's would do it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coquinn »</TD></TR><TR><TD CLASS="quote">Killer camshafts here:
305 Intake
295 Exhaust</TD></TR></TABLE>
Spec D's
Intake High (VTEC) 12.9mm 305
Exhaust High (VTEC) 11.9mm 315
305 Intake
Spec D's
I was running 14 to 1, JUN 3's with updraft ITB, with the Haltech E6k before and got rid of it. I am running Hondata with JUN 4's now, is a lot easier to tune comparing the two.
Dennis
Modified by Yunisden R at 6:41 PM 9/25/2003
Dennis
I would check out Import Builders website, and see what they're using.
Also, I've heard Toda vtec killers work best with the Toda ITBs or vice a versa.
Either way, ITBs underneath the hood just look SICK
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by genius »</TD></TR><TR><TD CLASS="quote">got some toda d's for sale
i made 260 whp on them with twm itb's.</TD></TR></TABLE>
how would you compare those with the Toda ITB's??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MEANB18 »</TD></TR><TR><TD CLASS="quote">Also, I've heard Toda vtec killers work best with the Toda ITBs or vice a versa. </TD></TR></TABLE>
I doubt it.
I doubt it.
I think it's a given that ITB's are gonna kill your bottom end, but how many drag races really start down low? I dunno, they sound fawking incredible, and I would mind having a set of ITBs if... only I had the money
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MEANB18 »</TD></TR><TR><TD CLASS="quote">I think it's a given that ITB's are gonna kill your bottom end, but how many drag races really start down low? I dunno, they sound fawking incredible, and I would mind having a set of ITBs if... only I had the money
ITB's are nice , but also im sure they also come with headaches lol
i have been told the itb's are best for auto cross then drag racing
</TD></TR></TABLE>ITB's are nice , but also im sure they also come with headaches lol
