over heated and now no compresion
Old Sep 22, 2003 | 08:15 PM
Glocked1's Avatar
Default over heated and now no compresion**Edit more ?'s**
I am picking up a 91 4 door this week from my friend that has been over heated and now I was told has no compression. I am thinking head gasket and warped head at the very least. any chance the cylinders or the valves would be screwed up? Thanks for any info.
Modified by AuggieDawgie at 2:51 AM 9/25/2003
Old Sep 22, 2003 | 08:38 PM
91hondacrx's Avatar
Default Re: over heated and now no compresion (AuggieDawgie)
If the major parts of the motor are screwed, odds are the smaller parts are as well. I believe you are right on with the head warped and head gasket. Depending on the motor you could find some really cheap replacement parts for it anyways, so either way you should be gettin a good deal. Engine swap, seems like a good time to do it.
Matt
Old Sep 23, 2003 | 11:09 AM
Glocked1's Avatar
Default Re: over heated and now no compresion (91hondacrx)
yeah Im paying $400 for the car and its an LX with a sun roof, power windows,locks and AC..its a decent car. A motor swap is pretty much out of the question...at least anything like a b16, because this is going to be my daily driver while I fix my other car that I blew the motor in the other day. Hopefully just the head gasket is the problem.
Thanks....anyone else have any input?
Old Sep 23, 2003 | 11:28 AM
91hondacrx's Avatar
Do you know what kind of motor is in it? I am thinking the d15b2, but could be wrong. IF you need any other d15b2 parts, i have some.
Matt
Old Sep 23, 2003 | 11:48 AM
Glocked1's Avatar
yeah its a d15. Ill hit you up if I need any parts. It needs a full headliner for sure..it just has the yellow foam hanging there.
Old Sep 24, 2003 | 05:51 PM
Glocked1's Avatar
OK so I did my own compresion today. Had like 10,10,70,120. Started from the left side of the motor when looking down at it. Bad compresion from a head gasket? Also there is a ton of water/oil aroud the piston sleeves. how do I get that out?
Old Sep 25, 2003 | 10:38 AM
Glocked1's Avatar
bump
rogersbm82
16
Apr 28, 2009 02:46 PM
mugen92acintls
Feb 9, 2004 05:50 PM
Nikolai
Jul 17, 2002 09:39 AM
