Anyone swapped a Type S RSX motor into a 2003 civic coupe?
Old Sep 22, 2003 | 07:44 PM
BlackB18CTeg's Avatar
Default Anyone swapped a Type S RSX motor into a 2003 civic coupe?
Just wondering if anyone has done this? And how quick is it?
Old Sep 22, 2003 | 08:00 PM
civicvtec1ps's Avatar
Default Re: Anyone swapped a Type S RSX motor into a 2003 civic coupe? (BlackB18CTeg)
lol not quick. time consuming . requires lot of $$$$
Old Sep 22, 2003 | 08:02 PM
Default Re: Anyone swapped a Type S RSX motor into a 2003 civic coupe? (civicvtec1ps)
you will need
K20A2 or K20A3 (from Civic Si) Engine With:
- AC compressor
- alternator
- P/S pump or idler pulley (from Civic Si)
- wiring harness
- exhaust manifold and catalytic converter
- ECU
- Transmission and starter
- intermediate shaft
- Axles from either 02 Civic Si or 94 up Integra GSR (we used 02 RSX with RSX knuckles and hubs)
- RSX or 02 Civic Si subframe
- Hasport ESK1 bolt in mount kit (as of this time the kit will not work with the K24)
- Hasport ESKWH conversion wiring harness
- RSX shifter assembly and cables
- 02 Civic Si radiator and fans (although the RSX will fit with some trimming around the radiator cap opening in the grill)
- 02 Civic Si upper and lower radiator hoses (RSX are longer and may kink)
- RSX throttle cable
- RSX fuel line, brake booster line and purge line
- RSX AC line from compressor to condensor
- RSX clutch lines from the master cylinder to the slave cylinder
- Custom AC line from compressor to evaporator (Hasport should have one available by April)
- 90 Accord negative battery cable
- If you want powersteering:
- RSX high pressure powersteering hose and return line
- 92 Civic P/S resevoir w/ bracket and a section of hydraulic hose to go from the pump to the resevoir
Old Sep 22, 2003 | 08:16 PM
JUN JDM's Avatar
damn...thats too much...should have just bought an RSX-S for all that trouble!!!
Old Sep 22, 2003 | 09:15 PM
Default Re: (JUN JDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUN JDM &raquo;</TD></TR><TR><TD CLASS="quote">damn...thats too much...should have just bought an RSX-S for all that trouble!!!</TD></TR></TABLE>
but you dont see much civic coupe with k20a2
Old Sep 22, 2003 | 09:54 PM
WrongWheelDrive's Avatar
Doesn't the new Civic "FP" edition come with a k20a3? You should just get that, then drop the k20a2 in there.... Correct me if I'm wrong.
Old Sep 23, 2003 | 03:35 AM
k20em2's Avatar
Default Re: (WrongWheelDrive)
there's a couple on 7thgencivic.com Also some turbo k20a2's in a civic coupe.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WrongWheelDrive &raquo;</TD></TR><TR><TD CLASS="quote">Doesn't the new Civic "FP" edition come with a k20a3? You should just get that, then drop the k20a2 in there.... Correct me if I'm wrong.</TD></TR></TABLE>
The "FP" edition comes with a d17. I wish they dropped a k series in the new civics.
Old Sep 23, 2003 | 03:38 AM
k20em2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackB18CTeg &raquo;</TD></TR><TR><TD CLASS="quote">Just wondering if anyone has done this? And how quick is it?</TD></TR></TABLE>
Someone did a k20a swap into a em2, he ran low 14's all motor. He's currently boosted making well over 400whp. Hasn't ran it at the track yet since his k20a ecu cuts out at 110mph.
Old Sep 23, 2003 | 07:33 PM
Slammed2K1's Avatar
New User
Default Re: Anyone swapped a Type S RSX motor into a 2003 civic coupe? (k20em2)
Working on one right now, trying to piece it together. it's an a3 though, but picked it up at a great price.
Old Sep 23, 2003 | 07:36 PM
Default Re: Anyone swapped a Type S RSX motor into a 2003 civic coupe? (Slammed2K1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slammed2K1 &raquo;</TD></TR><TR><TD CLASS="quote">Working on one right now, trying to piece it together. it's an a3 though, but picked it up at a great price.</TD></TR></TABLE>
nice
Old Sep 23, 2003 | 07:38 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k20em2 &raquo;</TD></TR><TR><TD CLASS="quote">
Someone did a k20a swap into a em2, he ran low 14's all motor. He's currently boosted making well over 400whp. Hasn't ran it at the track yet since his k20a ecu cuts out at 110mph. </TD></TR></TABLE>
yup paul(owner) ran 14.1( im pretty sure thats right numbers) thats with shietty shfiter , he replaced that. needed new tires because his current tires cant take power. keep slipping.
Old Sep 23, 2003 | 08:24 PM
4aceM2's Avatar
ya it is pretty hard to do that swap. i am debating wether to go all out on a k20 swap or just say on the more subtle side of things and just go turbo.
Old Sep 24, 2003 | 11:13 AM
Default Re: (4aceM2)
what boost can u run on the type s motor... all stock (cept for fuel of course)
Old Sep 24, 2003 | 03:08 PM
k20em2's Avatar
Default Re: (BlackB18CTeg)
I've seen guys on clubrsx boost 9psi daily. A couple turn it up to 10 at the track.
Old Sep 24, 2003 | 03:21 PM
CHILIBEANZ's Avatar
there was a civic coupe with a k20a(DC5R) motor in it this weekend at nopi. hasport makes the mounts. don't those cars weigh just as much as a type-s?? mike
Modified by p220 at 7:47 PM 9/24/2003
Old Sep 24, 2003 | 03:40 PM
Default Re: Anyone swapped a Type S RSX motor into a 2003 civic coupe? (p220)
there were couple coupe had k20 motors. one guy with silver coupe ,k20a2 with cybernation stage 2 turbo. and other custom orange one with bodykit. he had k20a motor swap
Old Sep 24, 2003 | 03:49 PM
CHILIBEANZ's Avatar
yeah all i saw was the orange one. anybody catch top secrets jdm dc5(not r but still jdm) w/hks turbo...good stuff.
Old Sep 24, 2003 | 04:19 PM
paikman's Avatar
Default Re: (p220)
an em2 (2001+ civic coupe) is much lighter than a typeS.
I think the weight difference was almost 200lbs. So you are running about the same as an ITR.
Old Sep 24, 2003 | 06:34 PM
dc2integra's Avatar
Default k20 em
honda tuning had an edition i think it was either july or august but it was devoted to a em civic k20 swap. you should look around for it or i could dig it up and send it to you. it had alot of useful info.
Old Sep 24, 2003 | 07:37 PM
k20em2's Avatar
Default Re: k20 em (dc2integra)
I saw that orange civic. how can you tell if it was a type-r motor. Did you guys see the k20a stamp on the engine block. I was speaking to those guys about the swap and they had no clue about the car. All they told me was that their shop did the swap.
Old Sep 25, 2003 | 04:22 AM
SlammedBlueEM2's Avatar
Default Re: (paikman)
An EM2's curb weight is 2556lbs. Technically, it's over 200lbs lighter than the Type S. DC5R's curb weight is 2596lbs.
One guy on 7thGen weighed his EX and I believe it came out to around 2350lbs.
Old Sep 25, 2003 | 05:20 AM
CHILIBEANZ's Avatar
oh o.k. i wasn't sure about the civic's curb weight. that actually makes it seem more worthwhile now.
k20em2- the orange civic was visibly stamped, but it had the DC5R 6 speed tranny and intake manifold. there were two guys there, one didn't know ish about the car but the other guy actually knew what he was talking about. the orange was a different color and went well with that blue pearl color but you would never catch me in that thing. seems like these shows are just getting more and more crazy with some of these cars. show me some more japan spec cars or clean conversions and i'll be happy. i don't particularly care about alteezas and hydraulics.
Old Sep 29, 2003 | 08:54 PM
Default Re: (k20em2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k20em2 &raquo;</TD></TR><TR><TD CLASS="quote">there's a couple on 7thgencivic.com Also some turbo k20a2's in a civic coupe.
The "FP" edition comes with a d17. I wish they dropped a k series in the new civics. </TD></TR></TABLE>
http://motoringzone.com/module...id=43
Read on the Civic "FP" it says it comes with a 160bhp engine... which I strongly believe is a k20a3 and they are test driving it. Its an article from road & track.
Old Sep 29, 2003 | 08:55 PM
Read on the Civic "FP" it says it comes with a 160bhp engine... which I strongly believe is a k20a3 and they are test driving it. Its an article from road & track.</TD></TR></TABLE>
thats bs!
fp come with d17. just has suspension , oem kit. fp rims. shiftknob, and little other things
Old Sep 29, 2003 | 09:19 PM
Default Re: (civicvtec1ps)
I don't know.. maybe it was a prototype they didn't go through with..
