Can set my timing
i went to a shop that had a timing light to get it set, the guy fiddled with the dizzy's mouning position for a while and then he told me that maybe there was a problem with the distributor because he couldnt set the timing farther that 5° advanced (should be at 16°).
What could it be?
The dizzy is fairly new but I dont know about the timing belt instalation (now at 110k miles and was changed at 90k). Maybe its a tooth off? Also maybe the crank pulley is of by a bit (or does it have only one mounting pos?)
PLease I need some help
What could it be?
So if the belt is a tooth off then the timing could be as messed up as it is right? Its all the way advanced and it has only 5° positive timing.
How can I check if it is a tooth off? Is there any visual way to know?
I could be going out on a limb here....but
I have seen the keys for the crank pulley get sheared, which would totally throw off your readings for timing, since it reads off the crank pulley.
If the timing belt is correct, and the dizzy is correct, then this could be a possibility.
Pull off the pulley and see if the key has sheared. If the pulley moved around a little, it will throw off your ignition timing readings
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jetpilot »</TD></TR><TR><TD CLASS="quote">TTT
this forum has degraded a lot</TD></TR></TABLE>
that's not a fair thing to say
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika »</TD></TR><TR><TD CLASS="quote">
I know, im sorry. I really like this place but sometimes you just can get even one answer and there are a lot of great people here. Ill take my valve cover off (i also want to set my valve lash) and if its not that then the pulley is coming off.
</TD></TR></TABLE>I know, im sorry. I really like this place but sometimes you just can get even one answer and there are a lot of great people here. Ill take my valve cover off (i also want to set my valve lash) and if its not that then the pulley is coming off.
Did you check the marks on the cam gear and crank pulley? If you changed the timing belt 20,000 miles ago...when did you notice you had a timing problem? At 5degrees it should be running like total crap.
I just bought the car and have a new timing belt in my parts bin bu havent insalled it yet, i want t get a new water pump. Tats what I thought and the car is fine, it pulls hard and doesnt have a ny trouble revving, when vtec hits you can tell the difference too!! Ill go to another shop to check my timing again
NatedoggAZ
14
Apr 13, 2005 09:51 AM
