anyone use dsm turbo pipes for their turbo apps?
the stock dsm turbo pipings are like like rubber hoses..kinda looks like radiator hose..but bigger and thicker..do you think its ok to use? its going on a garret t3 with a z6 block, y8 head..in a 90 hatch.
piping diameter is about 1.75"..kinda small..what size piping should i go for?
it was cheap and ugly, its not as ugly as some of the other methods. I've been using it for along time. I have a leak, but its not due to the pipes its my connections.
Nick
Nick
I use it
, works for me
its about 2-2.25"
the reason DSMers get rid of it for hard piping is becuase it expands. but yea it gets the job done, I still use like 65% of the stock piping. you'll gain more power with hard piping though
Modified by FourG63 97GST at 9:44 PM 9/27/2003
, works for meits about 2-2.25"
Yea, they're made for pressure and heat...worked perfect on my last set up and I'll probably use the old ones again until I replace little by little with metal.
so how are you guys connecting these hoses together? with little steel pipe pieces?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4g_civic_si »</TD></TR><TR><TD CLASS="quote">ahhh ok..so it works fine with 7psi right? anything more will blow up like balloons? </TD></TR></TABLE>
I run 16psi(T28) on mine
you'll be fine at 7
you'll be fine at 7
Half of my piping is made up from large diameter radiator hose.
Its rated at well over 30psi, and wont expand or "baloon" at all.
Very strong stuff.
Very strong stuff.
what diameter should it be?
anyone got some pix?! i wanna see how it looks like..is it rubber hose all the way around to the IM?
Modified by 4g_civic_si at 1:20 AM 9/30/2003
crap, I see it doesn't show much of the piping, LOL. You can see it start right there on the left. I have the charge piping laying in my room and if you guys really want a pic I can take one.
