4 Way hazzard lights don't work?
Old Sep 22, 2003 | 05:45 PM
jamal-188's Avatar
Default 4 Way hazzard lights don't work?
I'm not sure what happened, doesn do anything when i press the button on my 01 GSR. I can't find a fuse for them either?
Old Sep 23, 2003 | 03:16 AM
jamal-188's Avatar
Default Re: 4 Way hazzard lights don't work? (jamal-188)
nobody knows?
Old Sep 23, 2003 | 10:45 PM
jamal-188's Avatar
Come on, nobody at all?
Old Sep 25, 2003 | 08:56 AM
jamal-188's Avatar
ttt
Old Sep 28, 2003 | 08:07 PM
jamal-188's Avatar
up
Old Sep 28, 2003 | 10:15 PM
sil-15's Avatar
maybe all 4 of them got burned out from using them too much after winning all those races?
Old Sep 28, 2003 | 11:15 PM
thaiphob's Avatar
Nikon!!!
Default Re: 4 Way hazzard lights don't work? (sil-15)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sil-15 &raquo;</TD></TR><TR><TD CLASS="quote">maybe all 4 of them got burned out from using them too much after winning all those races?</TD></TR></TABLE>
lol nice one!
Old Sep 29, 2003 | 05:48 PM
stumpyf4's Avatar
Default Re: 4 Way hazzard lights don't work? (thaiphob)
The lights don't come on at all or it just stays constant. If it stays constant it's probably the flasher which is located in the fuse box under the dash. There are 2 of them, one for the signals and one for the hazards, they are different.
Old Sep 29, 2003 | 05:52 PM
The-LS's Avatar
you are going to have to give a lot of info on what wiring changes have been done to the car right before this happened. Obviously this is not a common problem so you'll have to check everything. I'd check ALL fuses first, then locate where flashers, relays, and associated wiring to the hazard system are located and check all of them. Does the horn work?
Old Oct 2, 2003 | 06:46 AM
jamal-188's Avatar
Default Re: 4 Way hazzard lights don't work? (Black-LS)
The lights don't come on at all. When I press the button nothing happens, no noise, no lights nothing, but my turn signals work fine. I think the lights stopped worked when I hade a burnt out front corner light. I just don't know what else to check besides fuses, which are all ok.
defensa24
Mar 8, 2011 06:45 AM
MR Rodgers
Aug 25, 2007 01:56 PM
Spoolinator
Mar 15, 2006 09:36 AM
HondaHemi
Feb 3, 2006 11:12 PM
Marcos
Mar 23, 2004 11:21 AM
