When OBD1S Go Bad?
Old Sep 22, 2003 | 04:39 PM
94gsrsedan's Avatar
Default When OBD1S Go Bad?
What are some signs of your ecu going bad? Could this be the problem with my car . It was running really crapy and now its not running at all. The rpm's would go all crazy the car would just cut off out of no where. If a lower vtec anywhere from 5700 like to 52,53 it would be ok then i would be on the highway like the next day and car just start loseing power or bog just something off the wall. My 1/4 times are crap it ran faster with just a intake and header and it had 100 pound box in the back 15.9@89mph then last year. This year it couldn't even break 16 flat on street tires 15.2@91.69 on slicks. Please Help! Sorry for the bad Engish and spelling
94 GSR sedan green 150,xxx right now
Aem cai, fuel filter,DC SPORTS 4-1 header,SKUNK2 stage 1 cams,
cam gears,valves,coilovers,vtec controller,short shifter,itr valvesprings,
,ACT extreme clutch,12.5 lighten flywheel,phamtom grip,Tokico 5 ways,
ROTA 15" black ss wheels,B&M fuel psi regulator& gauge 2.5 high flow cat,
Apex exhaust
Old Sep 22, 2003 | 06:11 PM
JMod's Avatar
Default Re: When OBD1S Go Bad? (94gsrsedan)
maybe you should do a compression & leakdown test and see what you get with that. Not a bad place to start.
Old Sep 23, 2003 | 04:22 PM
94gsrsedan's Avatar
I did one last december they were all around 15% lean down then. Might be time for a rebuild thats what i was planning on doing this winter anyway. thanx for the imput
Apex exhaust
Old Sep 23, 2003 | 04:23 PM
94gsrsedan's Avatar
leakdown*
importtuner07
34
Aug 16, 2006 11:35 PM
BRWFIT
13
Aug 12, 2003 09:07 PM
b16powwer
Feb 2, 2003 12:06 PM
