What turbo should i use for 15-20 psi on my b16a?
Same as title...gimme ur opinions. and dont give me that noob crap. I know what I have done my research, but Im sure someon on here know a little more than I do, so let me know if im right...
Thanks guys
Thanks guys
What are your hp goals? be realistic. street or race car? spool up goals? redline? other mods? there is a lot involve here.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared »</TD></TR><TR><TD CLASS="quote">What are your hp goals? be realistic. street or race car? spool up goals? redline? other mods? there is a lot involve here.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX TypeR »</TD></TR><TR><TD CLASS="quote">Same as title...gimme ur opinions. and dont give me that noob crap. I know what I have done my research, but Im sure someon on here know a little more than I do, so let me know if im right...
Thanks guys
If you wern't a noob and had done your research you wouldn't be asking us a hugely vague question like this.
Thanks guys
</TD></TR></TABLE>If you wern't a noob and had done your research you wouldn't be asking us a hugely vague question like this.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted92 »</TD></TR><TR><TD CLASS="quote">
If you wern't a noob and had done your research you wouldn't be asking us a hugely vague question like this.</TD></TR></TABLE>
true
true
would you guys get off his back? I thought this was a cool forum..What's the big deal of asking about what we think about which turbo he should get? how's that a HUGE question..It seems to me that he already has his plans and wants to see what other people thought.
You don't have a lot of room to play with in that CRX, but toss on a T3/T04E with an exhaust a/r of .63 and you'll be fine. When you want to start making mad hp and boost 20+ then step up and get a full T4.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uoboarder »</TD></TR><TR><TD CLASS="quote">You don't have a lot of room to play with in that CRX, but toss on a T3/T04E with an exhaust a/r of .63 and you'll be fine. When you want to start making mad hp and boost 20+ then step up and get a full T4. </TD></TR></TABLE>
Hey thanx man. I dont know how much boost that can handle. My plans have changed as of late. I am now getting a b16A 1st generation. And I need a turbo that can handle up to 20 psi? Any idea on best turbo for this application??
Thanks guys!
Thanks guys!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX TypeR »</TD></TR><TR><TD CLASS="quote">And I need a turbo that can handle up to 20 psi? Any idea on best turbo for this application??
Thanks guys!
You are an idiot. You just asked the same stupid question twice
BAN
Thanks guys!
</TD></TR></TABLE>You are an idiot. You just asked the same stupid question twice
BAN
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bryan305 »</TD></TR><TR><TD CLASS="quote">
BAN</TD></TR></TABLE>
ahhaa, thats the funniest thing i read all day.
i really dont think this kat knows what he is gettin into, wants to run 15-20 psi on a b16.. 1st gen
before you comit suicide go take a peek around on the forums and see what other people hae on their rides that allow them to run
15-20 psi safely.
you will end up spending a good amount of cash to make it be fast and reliable.
BAN</TD></TR></TABLE>ahhaa, thats the funniest thing i read all day.
15-20 psi safely.
nah man dont listen to these haters, what you need is a t76(turbo) run that **** at 30 psi but one thing you will have to do it raise the redline so you will be able to spool it up all the way but dont worry b16s love to rev and you can get the chips on ebay just look for the ones that remove the revlimiter. hope this helps
Yes I did, but I dont want that vague question BS again..BTW, WTF is this I quoted from you? thanks for you help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nevin »</TD></TR><TR><TD CLASS="quote">nah man dont listen to these haters, what you need is a t76(turbo) run that **** at 30 psi but one thing you will have to do it raise the redline so you will be able to spool it up all the way but dont worry b16s love to rev and you can get the chips on ebay just look for the ones that remove the revlimiter. hope this helps</TD></TR></TABLE>
easy on the poor guy
go with a t3/t04e with like a .63 A/R and you will like it unless you go crazy and pick up a sc61 T4 then you are talking
but make your goal realistic it dont take alot of hp to make a light car like that fast
think about it as power to weight ratio and go from there
hp goals are more important than psi. I would figure out how much you want to spend first, then pick a reasonable hp goal, then begin to see what you might be interested in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -TRINiTRON- »</TD></TR><TR><TD CLASS="quote">hp goals are more important than psi. I would figure out how much you want to spend first, then pick a reasonable hp goal, then begin to see what you might be interested in. </TD></TR></TABLE>
this is very true becouse i have seen on here 375 whp i beilive on 11 psi of boost with a sc61 with a stock gsr motor tunned
is this a built motor??? 15-20 psi can be pretty unreliable on a stock block, but if its built, a sc61 will prolly make the most power. check out precision turbo, their stuff is the ****!! i gotta a smaller t3/t4 and it makes some GOOD power. enough to satisfy me.... for now
i cant find the link or remember who did it but it wasn't to long ago
375 whp 17psi of boost 3mm head gasket head studs bigger injectors and hondata
maybe someone else's remembers this guy or post i cant seem to find it right now
i'm not sure but i think this guy just told him to commit suicide?
well it will be a fun ride while it last's (not sure how long that will be)
QUOTE=mist Si]
[/QUOTE]
I think it was intended to be a joke dude.[
[/QUOTE]I think it was intended to be a joke dude.[
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dublocivic »</TD></TR><TR><TD CLASS="quote">QUOTE=mist Si]
I think it was intended to be a joke dude.[[/QUOTE]
yeah i guess sarcasm doesn't come off as well posting
</TD></TR></TABLE>I think it was intended to be a joke dude.[[/QUOTE]
I am willing to spend whatever it takes to get the best turbo for this. But the max boost I want is 20psi. I will have a built block an upgraded head. including, but not limited to, pistons, new rods, valves, retainers, cams, head studs, and possibly a 3mm headgasket. Overall, I plan to spend on upgrading the motor and turbo setup; about 4-5K. I know of some good deals around here
Everyone thanks fro the advice, but I know how much im plan to spend, BTW this is the first time I hear of a sc61 turbo. Can someone give me a link to a website or something? How much boost can a T4 handle guys?
sorry but i don't think your being realistic. You only want to spend 4-5k on your motor and turbo setup. Add up the parts and you'll be well over that. A lot of guys here have spent that much on just the turbo setup alone. Also don't just ask what turbo will be good for 20lbs. That's a vague question. How much power are u tryin to make is a better question.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX TypeR »</TD></TR><TR><TD CLASS="quote">I am willing to spend whatever it takes to get the best turbo for this. But the max boost I want is 20psi. I will have a built block an upgraded head. including, but not limited to, pistons, new rods, valves, retainers, cams, head studs, and possibly a 3mm head gasket. Overall, I plan to spend on upgrading the motor and turbo setup; about 4-5K. I know of some good deals around here
Everyone thanks fro the advice, but I know how much im plan to spend, BTW this is the first time I hear of a sc61 turbo. Can someone give me a link to a website or something? How much boost can a T4 handle guys?</TD></TR></TABLE>
a sc61 is a precision turbo and it is one of the best for the money and i only heard of good from them
i owned one but i sold it due to money reasons
Rod over at precision turbo said i will get peak hp out of that turbo at about 28-32 psi but it comes alive at like 12 psi and goes up from there
it is the turbo i am going to be going with over winter
and if you have pistons and rods why you using a thinker head gasket unless you have higher then say 9:1 comprestion pistons
please explain you hp goals it will make it easier to go though when you have that accomplished
