removing crank pulley bolt...but
Old Aug 23, 2001 | 06:47 PM
Jesse H's Avatar
Default removing crank pulley bolt...but
while the motor is on an engine stand...no flywheel to hold. ?
Service manual mentions a tool, my local honda dealership never has any "special tools" in stock. Any ides? My air tools don't have enough umph either. This is B16 that looks like it's been sitting at Nippon for awhile.
thanks all...
Old Aug 23, 2001 | 07:31 PM
8Ball's Avatar
Default Re: removing crank pulley bolt...but (Jesse H)
I think summit has a tool that inserts into the pulley to hold it, it is hexagon shaped to fit the hexagon on the pulley and it has a hole in the middle so you can insert your socket in and a handle to hold onto it so it doesn't move. Someone posted awhile back their own homemade version but i'm not sure where that pic is.
Old Aug 23, 2001 | 11:50 PM
sgT's Avatar
sgT
Default Re: removing crank pulley bolt...but (8Ball)
GO to home depot, lowes or whatever place you got out there and look
for a bar with a chain attached. I dont know the exact name but its
a tool that plumbers use to turn pipes with nothing to grab on to.
Get the largest one you can find and use that to hold onto the
crank pulley while you go at the bolt with a breaker bar.
Old Aug 24, 2001 | 08:30 AM
LsVtecADR's Avatar
New User
Default Re: removing crank pulley bolt...but (sgT)
yeah, i used a pipe wrench too...got one for 15.00 at harbor freight tools-
Old Aug 24, 2001 | 07:15 PM
BreakStuff's Avatar
New User
Thats funny, the Honda dealership I work in never has any special tools available either!..
their always secretly hidden in other tech's toolboxes!
Old Aug 25, 2001 | 09:18 AM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
strap wrench
Old Aug 25, 2001 | 07:54 PM
8Ball's Avatar
all good ideas, if you do really want that tool, it is a moroso part, in the moroso catalog, it is 61805, honda/acura crankshaft pulley wrench, though i'd imagine it's at least 40-50 dollars, when a strap wrench is considerably less... where's your flywheel?
Old Aug 26, 2001 | 09:05 AM
earl's Avatar
I was on a Snap-On truck the other day and they had a tool made for the Honda balancer pully. You attached it to a breaker bar. It was about $60.
Old Aug 26, 2001 | 05:15 PM
speedworks's Avatar
if all else fails, heat the bolt with a torch until red and then the weakest impact wrench in the world will remove it
Old Aug 26, 2001 | 05:40 PM
martini's Avatar
Default Re: removing crank pulley bolt...but (ho focker)
sears has a rubber strap wrench that works well.
Old Aug 26, 2001 | 10:12 PM
Big Ed's Avatar
Default Re: removing crank pulley bolt...but (LsVtecADR)
Ah, Harbor Freight, the .99 cent tool store . That place is great.
Old Aug 26, 2001 | 11:06 PM
autoduel's Avatar
Default Re: removing crank pulley bolt...but (Big Ed)
You don't need to hold it if you use an impact wrench.
If you're using a breaker bar. take out a sparkplug and insert about 8" of nylon rope into the chamber. make sure it's BTDC w/ the valves closing.
Xscort
Jul 25, 2008 10:54 PM
budomove
Nov 2, 2007 07:26 AM
grngsr01
Oct 23, 2005 05:47 AM
flip1199
Nov 12, 2004 06:50 PM
94vtecmn
Apr 21, 2003 12:08 PM
