Hasport A/C bracket Or GSR compressor
Old Sep 22, 2003 | 11:26 AM
Big Bang's Avatar
Default Hasport A/C bracket Or GSR compressor
Doing the B18C1 swap in my CRX so if they are about the same price which should i do?
Old Sep 22, 2003 | 01:17 PM
I Want An Si's Avatar
Default Re: Hasport A/C bracket Or GSR compressor (The Converted)
1) Yes the GSR compressor will bolt up with the proper Brackets
2) The GSR compressor is meant for r134a
3) Your A/C System is meant for r12
4) Even though the GSR compressor will bolt up to the engine, it will sit too low and hit the crossmember
5) Save yourself the Trouble and get a hasport a/c bracket(works for both Matsushita and Sanden Compressors)
6) If you want to save money get the place racing or hcp bracket(note this will only work if you have a Sanden Compressor)
7) Regardless of what a/c compressor/OEM bracket combination you use it wont work because itll sit too low and hit the crossmember...
8) dont convert to r134a or use freeze 12 or any other "safe for the enviroment refrigerants", youll hate yourself if you do
Old Sep 22, 2003 | 04:46 PM
Eggman's Avatar
Default Re: Hasport A/C bracket Or GSR compressor (I Want An Si)
what happens if you conver to r134a?
Old Sep 22, 2003 | 06:31 PM
Default Re: Hasport A/C bracket Or GSR compressor (Eggman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eggman &raquo;</TD></TR><TR><TD CLASS="quote">what happens if you convert to r134a?</TD></TR></TABLE>
then you reduce the efficiency of the r12 system.... will it be cold? yes...will it be as cold as r12? never
censurebush
Sep 5, 2007 10:48 AM
94eh2
Mar 13, 2007 05:53 PM
Sivicfied
Jul 24, 2006 03:13 PM
93b16CivicSi
Aug 17, 2005 09:51 AM
Stripped Honda
Jun 15, 2005 07:05 PM
