Question about S-AFC?
Old Aug 23, 2001 | 06:14 PM
Speed PHreak's Avatar
Default Question about S-AFC?
Ok, i've got it in. It's hooked up wired in correcty. I'm just wondering how sensitive the throttle % is? If I rool the throttle to the floor it will start reading. But if i'm just normal driving it always sits at 0%. Is this normal? Maybe I need to change my TPS? Any help appreciated
~steven
Old Aug 23, 2001 | 06:48 PM
non-VTEC's Avatar
Default Re: Question about S-AFC? (Speed PHreak)
you might have it hooked to the wrong wire or the SAFC unit is not working correctly. you should get a throttle position reading all the time from 0%-100% depending on how much you press the throttle.
Old Aug 29, 2001 | 06:24 AM
rioninja's Avatar
did you allow the afc to set base settings? your supposed to hold the throttle fully open for 10 seconds so that it can get an average 100% reading (or something like that).
Old Aug 29, 2001 | 07:30 AM
Default Re: Question about S-AFC? (RioNinja)
Iit's ok now, I just took it out i'm just gonna get a zdyne ecu........anyone want a month old S-AFC? Still in the box? 300?
00si2
Nov 19, 2012 08:26 PM
99lspwr
Feb 4, 2004 04:45 AM
Goldfingiz
Jul 22, 2003 01:26 PM
zilverz
Jan 27, 2003 12:25 PM
