flywheel bolts..easiest way to take off..
Old Sep 22, 2003 | 08:57 AM
VRD^don's Avatar
Default flywheel bolts..easiest way to take off..
need help fast..trying to take off my flywheel bolts and having a hardass time taking them out...you guys know an easier was to remove them..already rounded out three of them..please help...thanks...
Old Sep 22, 2003 | 09:00 AM
FasteddieIX's Avatar
Default Re: flywheel bolts..easiest way to take off.. (sohc_vtec)
WD40?
Old Sep 22, 2003 | 09:02 AM
VRD^don's Avatar
Default Re: flywheel bolts..easiest way to take off.. (FasteddieIX)
already did that..took impact to it...used a long *** breaker bar...and it wont bugge.....already try heat and still wont come out..
Old Sep 22, 2003 | 12:01 PM
Double121's Avatar
I used a strong impact gun to get mine off....Don't know of any other easy way than that. Maybe ur impact gun doesn't have enough stuff??? U need an incredible hulk impact gun.
Old Sep 22, 2003 | 01:47 PM
sackdz's Avatar
How do you round off a 12 pt bolt?
It was 12pt right?
Old Sep 22, 2003 | 02:42 PM
95hatch's Avatar
Default Re: flywheel bolts..easiest way to take off.. (sackdz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sackdz &raquo;</TD></TR><TR><TD CLASS="quote">How do you round off a 12 pt bolt?
It was 12pt right?</TD></TR></TABLE>
Yea make sure your using a 12 point socket. All i did was held the crank pulley bolt in place while i loosened the bolts. they werent on there very tight.
Old Sep 22, 2003 | 02:43 PM
Big Teggie's Avatar
They shouldnt be on that tight.
Just use a long breaker bar and they should come off no problem.
Old Sep 23, 2003 | 06:41 AM
VRD^don's Avatar
yeah..i used a 12 pt socket with a long *** breaker bar..
Old Sep 23, 2003 | 08:10 AM
PupaScoopa's Avatar
It sounds like somebody overdid it with some thread lock...
Old Sep 23, 2003 | 08:44 AM
JdmegFOUR's Avatar
Default Re: flywheel bolts..easiest way to take off.. (PupaScoopa)
USE A 1/2 in impact and let the air compressor charge all the way up
to like 120 psi
THEN LET HER RIP...impact is nicer than BREAKER BAR
Old Sep 23, 2003 | 08:48 AM
naturelovindc2's Avatar
I was having trouble getting the bolt off my crank pulley one time using a real strong gun. A guy told me to put an extension on the impact and it came off first try.
Old Sep 23, 2003 | 09:18 AM
jerseybrandon's Avatar
make sure the compressor has enough *****, not just the gun.
Old Sep 24, 2003 | 08:48 AM
VRD^don's Avatar
Default Re: (jerseybrandon)
oh yeah the compresor has enough *****..10hp 80 gallon compersor..it should had enough *****..but the gun i don't know...
Old Sep 27, 2003 | 01:55 PM
MisterB's Avatar
Default Re: (sohc_vtec)
did you get them off?
if there is loctite on the bolts you need to use heat(heatgun) or hit them in order to break up the loctite
Old Oct 1, 2003 | 08:58 AM
VRD^don's Avatar
Default Re: (MisterB)
not yet but going to try heat it up..thanks..
Old Oct 1, 2003 | 10:38 AM
5thgencivic's Avatar
Just don't slip off with the impact like I did once Never did it again. Just rounded the bolt a tiny bit. The only thing I had was an electric impact and all the bolts came right out pretty quick..
Old Oct 1, 2003 | 10:48 AM
Trooper's Avatar
Default Re: (5thgencivic)
Try oiling the gun, and make sure that its on its highest setting
Old Oct 1, 2003 | 12:08 PM
civic-king's Avatar
try that stuff.....PB blaster it's the best!!
Prudz_lude
Feb 23, 2008 10:06 PM
creechrr
Apr 21, 2004 09:44 PM
VWkila
17
Mar 31, 2004 05:53 PM
Gonzo_SiR
Nov 5, 2003 07:37 AM
chrdal
Feb 18, 2003 08:24 AM
