Venom V-400 Group buy!!! 25% more power cheap
Old Sep 22, 2003 | 08:45 AM
natesgarage's Avatar
Default Venom V-400 Group buy!!! 25% more power cheap
I just wanted to post this and see how many people would be interested in it. If you are PM me. I listed the web site so you can see what i'm talking about.
http://www.venom-performance.com/nf/html/v400.htm
This is what they're saying:
"The Venom400 performance control module is an add on control unit that features it's ownmicro-controller. This module is connected to the throttle position sensor and the Manifoldabsolute pressure sensor, and by monitoring the sensors output characteristics and modifying the input signal to the vehicles existing ECU.
Improving horsepower by as much as 25% through the range of approximately 1,000 - 5,000 RPM. The Venom400 is OBD II compatible. Besides substantial increase of torque, the Venom400 reduces the flat spots or delay timing during sudden accelerations. Incorporated into the Venom400 is an 8-bit micro-controller that is capable of monitoring the various sensor inputs and modifying their outputs at more than 40 times per second.
If you already have another performance prom installed not to worry the venom400 is a mid range performance chip and the prom chip is a wide open throttle application thus complementing each other through the entire RPM band. The Venom400 has an on/off switch so smog certification is possible without detection of unit. Easy installation with basic hand tools requiring only four electrical connections.Loss of gas mileage to be expected is 1-3 miles per gallon in fuel economy. No significant damage or long term stress side effects in long and short range testing."
Here is application chart so you can see if they have it for your car:
http://www.venom-performance.c...1.htm
Old Sep 22, 2003 | 09:10 AM
carolinaACCORD's Avatar
Default Re: Venom V-400 Group buy!!! 25% more power cheap (nate007is)
Is the group buy for $10?
Because that's all that I would pay for that.
1-2 hp MAX. Utter waste of money.
1000_miles
Dec 20, 2006 03:28 PM
rleonekc
Mar 12, 2006 07:42 PM
natesgarage
11
Sep 22, 2003 09:06 PM
natesgarage
Sep 22, 2003 10:02 AM
