F22A1 to F22A swap problem!!!HELP
Old Sep 22, 2003 | 08:30 AM
halfNhalf-83's Avatar
Default F22A1 to F22A swap problem!!!HELP
Hey guys i need some serious help with this one. I had recently swapped out my F22A1 engine for a 140hp/145lb for my 92 accord. The one problem i have here is that the air intake bypass valve is disabled cuz my original wiring harness didnt have the right plugs nor did i have the little soleniod to have the valve work. So now i have huge horsepower lag until 2300 rpm then i get the power this is partially because there are dual runner plates inside the intake manifold which the valve is supposed to open and close depending on the rpm for either low end torque or high end horsepower.So is there a way i can still hook this up!!AN IDEAS??ANY THOUGHTS???
THANX
Old Sep 22, 2003 | 12:11 PM
miege44's Avatar
Default Re: F22A1 to F22A swap problem!!!HELP (SMseagren83)
no problem, just get the harness plug and solenoid from an accord with an f22a6, you may need the ecu also, wire it up from harness to iab to ecu.
no probleM, JUST a little setback in the ent9re shcme of things.
Sergio Ruiz
Jul 30, 2018 06:39 AM
Zealot Prime
May 30, 2016 11:00 PM
halfNhalf-83
Jul 15, 2004 11:06 PM
halfNhalf-83
Jul 15, 2004 11:05 PM
