What compression best good for Spoon Cams?
Old Sep 22, 2003 | 05:02 AM
Black Sheep's Avatar
Default What compression best good for Spoon Cams?
I have a ITR at 11.1:1 and getting some spoon cams. I was either thinking of Spoon/Mugen Gasket or some pistons.
Thanks
Old Sep 22, 2003 | 10:44 AM
B2FiNiTY's Avatar
Default Re: What compression best good for Spoon Cams? (Black Sheep)
As high as you want to go. Spoon cams aren't the ideal cams to go with if you want max power.
Old Sep 22, 2003 | 11:14 AM
Default Re: What compression best good for Spoon Cams? (B2FiNiTY)
ok thanks bro, pistons then.
Old Sep 22, 2003 | 11:40 AM
ill phil's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black Sheep &raquo;</TD></TR><TR><TD CLASS="quote">ok thanks bro, pistons then.</TD></TR></TABLE>
I think what he's trying to say is that pistons aren't needed. They aren't super high comp. cams. They are mild cam like the spec A's etc.
Old Sep 22, 2003 | 01:50 PM
Default Re: What compression best good for Spoon Cams? (ill phil)
I think B2FiNiTY means that if I'm looking for top end Spoon aren't the cams but the compression will help the pistons reload faster as they will with any cam. I was more concerned about to much compression causing powerloss/overlap.
95BlkGSR
Aug 21, 2004 04:29 PM
dElSleepiE
May 9, 2004 11:55 AM
Drag-On
Oct 17, 2002 12:46 AM
otacon
Mar 17, 2002 07:14 PM
cruzersi99
Aug 7, 2001 06:28 PM
