CEL from hitting a bump?
Old Sep 21, 2003 | 10:34 PM
erniecars's Avatar
Default CEL from hitting a bump?
I got a b16a1 in my 90 teg. I get a cel randomly about once every month. I checked the codes and its always either 1, 23, or 21. The latest was 21. I know the 23 and probably the 1 is from loose connectors but the 23 has me stumped. All i know is one time i hit a nasty bump and that light came on.
So my question is:
Is it possible to get cel 23 (knock sensor) if you hit a really bad bump in your lowered car? Like can it jar the engine hard enough to fool the sensor into thinking your engine knocked?
Thanks guys.
Old Sep 21, 2003 | 11:09 PM
Kamin's Avatar
Default Re: CEL from hitting a bump? (erniecars)
all the knock sensor is, is a sensitivite microphone. im sure its possible to have this happen but ive never heard of it before
Old Sep 22, 2003 | 12:03 AM
sirminder's Avatar
how well are your engine mounts/bushings holding up? could be that the impact from the bump could is not being asborbed as much.
Old Sep 22, 2003 | 01:19 AM
kwil666's Avatar
Default Re: CEL from hitting a bump? (sirminder)
i had a problem with my car throwing a code 23 it was always when i hit a bump or something. turns out my wire that had been run for the knock had some of the plastic covering worn away near the ecu. so when i would hit the bump or the whatever would cause it to show up, it was just the wire gounding out. i guess what im saying is check the back and front of your wires.
keith
Old Sep 23, 2003 | 10:07 AM
erniecars's Avatar
Default Re: CEL from hitting a bump? (kwil666)
i checked the wires and they are secure. My motor mounts are extremely stiff poly filled.
DFW
Texas -OK -LA (Sales)
11
Dec 30, 2012 07:30 AM
teamvirus
Feb 13, 2010 05:10 PM
silverbullet9626
20
Aug 12, 2008 12:08 PM
driftinflyboy
Apr 16, 2006 01:18 PM
skimb37
Feb 11, 2004 10:23 AM
