Determining Tach accuracy - Whats ur rpm at?
Old Sep 21, 2003 | 07:36 PM
Chemicalviper's Avatar
Default Determining Tach accuracy - Whats ur rpm at?
What is your rpm @ 70 80 in 5th gear = for gsr
How high does 2nd gear go ? i believe mine is 68 - im just suspicious
at 70 im at 3700 - nearing 4k at 80
this accurate?
<U>UPDATE AT THE BOTTOM - plz look if you know how to readjust tach</U>
Modified by Chemicalviper at 1:17 AM 10/21/2003
Old Sep 21, 2003 | 07:40 PM
greebler's Avatar
Default Re: Determining Tach accuracy - Whats ur rpm at? (Chemicalviper)
my tac in my cluster is 300 rpm higher than what my Field vtec controller says. (which is right).
Old Sep 21, 2003 | 07:45 PM
thanks that helps me so much lol
Old Sep 21, 2003 | 07:52 PM
B2FiNiTY's Avatar
Default Re: (Chemicalviper)
Every tach is different.
Old Sep 21, 2003 | 08:49 PM
wall of tvs's Avatar
Default Re: (B2FiNiTY)
This is somewhat of a redundant question -- the speedo that you are using as a "yardstick" for measuring the accuracy of the tach is MUCH less accurate (and influenced by a greater number of factors) than the tach itself.
Maybe you should be asking if the speedo is accurate according to your engine rpm.
Either way, the numbers that you have given seem to be about right.
Old Sep 21, 2003 | 09:19 PM
Default Re: (wall of tvs)
Here is the rpm vs speed equation I figured out -- using this, you will be able to figure out your top speed in any gear, speed at a given rpm in any gear, etc..
speed x wheel revs per mile = (rpm x 60)/(gear ratio x final drive)
Old Oct 20, 2003 | 10:17 PM
<U>UPDATE</U>
My tach gets gradually off - less than 100 at idle - but at redline its almost off by 400 by 8200 rpm - Is there anyway to fix it ? Maybe with the screw holding the needle in at the back of the cluster?
By the way i figured out its accuracy with my VAFC.
Old Oct 20, 2003 | 11:16 PM
bump
integraL's Avatar
well it also depends on your tranny also. gsr tranny - 5th gear - 80mph should be on 4000k....like dead on
Old Oct 20, 2003 | 11:23 PM
nah man ya didnt read hehe - at 70mph ... my tach shows 3700rpm ... but the vafc shows true rpm is 3500 .....
My question is how to readjust it so its back to normal. Nothing to do with tranny I BELIEVE - its the needle.
Old Oct 20, 2003 | 11:30 PM
integraL's Avatar
oh ok im sorry...didnt read on me
Old Oct 21, 2003 | 12:02 AM
TurboTeG4's Avatar
Default Re: Determining Tach accuracy - Whats ur rpm at? (greebler)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by greebler &raquo;</TD></TR><TR><TD CLASS="quote">my tac in my cluster is 300 rpm higher than what my Field vtec controller says. (which is right).</TD></TR></TABLE>I got my guage the tach and vafc and they are not all the same You think if I put my autometer tach to my msd box it would get a more accurate signal?
Old Oct 21, 2003 | 05:51 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
OEM tachometer is never accurate. I wouldn't worry about it that much.
Old Oct 21, 2003 | 06:03 AM
P1mpSlap's Avatar
same.
you find out when you are on the dyno. But lots of things can varry the OE tach which is usally slow from the factory in the first place.
Old Oct 21, 2003 | 06:08 AM
tachyteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chemicalviper &raquo;</TD></TR><TR><TD CLASS="quote">= for gsr How high does 2nd gear go ? i believe mine is 68 - im just suspicious</TD></TR></TABLE>
if you are getting up to 68 in 2nd gear then you are revving almost to 9 k. There is a speed/RPM calculator on http://www.car-videos.com at 8200RPM a gsr will hit 64mph in 2nd gear.
Old Oct 21, 2003 | 07:57 AM
so there is no way to readjust needle?
Old Oct 21, 2003 | 08:19 AM
hypa's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chemicalviper &raquo;</TD></TR><TR><TD CLASS="quote">so there is no way to readjust needle?</TD></TR></TABLE>
Nope.
The oem tach is only capable of going so fast in it's closed loop setup. Light mods, lightened flywheels, etc are all enough to throw it off.
If you're worried about it, do what I did.
Buy a small 4" 10k rpm tach from autometer, or wherever and mount it to your steering column. It works like a charm, and allows you to get a true tach reading, and not one that's 400rpm late.
Old Oct 21, 2003 | 12:21 PM
stevieteg's Avatar
if your tach is 400rpm's off, then when you shift at the redline on the oe tach, dosen't the rev limiter kick in before you even get to the 8,200rpm mark on the oe tach? And isn't this a big deal? I know chemicalviper floated a valve from over reving, even though he was shifting at redline.
Old Oct 21, 2003 | 10:23 PM
Bleh - only one way to figure out ... goto 8 grand and slowly rise rpms see if it does redline at 82 on tach but it hink its 78 on vafc - .... this will be fun ahh god.
coot_er
11
Apr 1, 2020 04:45 PM
stealth89hatch
13
Jun 17, 2005 03:25 PM
esca
Dec 12, 2004 05:03 PM
BiG Chris
Oct 11, 2004 05:58 AM
