Precision turbo oil requirments? need good info
Old Sep 21, 2003 | 06:39 PM
turboex's Avatar
Default Precision turbo oil requirments? need good info
Ok the turbo is a SC61, This is on a SR20DET, Now does it need a straight oil feed from block just like the stock turbo? See the stock turbo uses a banjo fitting that goes into the block in the oil pressure galley. However the banjo fitting (part that goes in block) Is normal size but has hole in it just a bit bigger that a pin in the center. The fitting works as a reducer to slow the oil flow to the turbo. Im guessing so it does not blow the seals out. Now im installing a SC61 will this turbo need the same restriction as the stock turbo? Or should I just run a hose stright from the oil location on the side of the block with a normal pipe to hose fitting, just like done on hondas? Thanks for the help and input
Civic420life
Apr 12, 2014 03:01 AM
delsoldrew
Sep 4, 2006 12:56 PM
chihuahuamanx
Jan 23, 2005 03:42 PM
hybridpatient95
Nov 1, 2004 12:54 PM
MikeMAN
Mar 4, 2003 04:35 AM
