changed clutch.. speedometer isnt working.. DA teg..
Old Sep 21, 2003 | 06:35 PM
turbo_ef9's Avatar
Default changed clutch.. speedometer isnt working.. DA teg..
okay.. so i changed my friends clutch on his 91 teg.. on the VSS has those two hoses.. well i pulled them off and of course hella PS fluid drained out.. well.. now that everything is back together, how come the speedometer doesn't work anymore? rpm works but no speed..? input.. and yes... i refilled the ps container thing
Old Sep 21, 2003 | 06:53 PM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
Default Re: changed clutch.. speedometer isnt working.. DA teg.. (eli_vang)
was the speed sensor damaged when u pulled the tranny off...and what does PS (im guessing power steering u mean) fluid have to do with the speed sensor?(VSS)and changing the tranny?
Old Sep 22, 2003 | 04:37 AM
TimoneX's Avatar
New User
Default Re: changed clutch.. speedometer isnt working.. DA teg.. (bruceleeroy)
Look into the speedo cable and sensor toward the rear of the tranny.
Old Sep 22, 2003 | 04:44 AM
sleeper4dr's Avatar
is this a mechanical VSS? if it is, it sounds like the speedo cable isnt seated properly. you dont have to put PS fluid into the VSS for it to work.
Old Sep 22, 2003 | 11:35 AM
turbo_ef9's Avatar
Default Re: changed clutch.. speedometer isnt working.. DA teg.. (sleeper4dr)
okay.. i'll make sure to check how far seated the cable is in the vss..
meCka
Feb 27, 2008 11:37 PM
1992hludesi
Dec 12, 2005 05:16 AM
No
Nov 3, 2004 04:40 PM
t . b o z
Apr 11, 2004 01:26 PM
turbo_ef9
Sep 22, 2003 12:40 PM
